Question about Starbucks Saeco Italia Digital Barista Coffee Machine
After one steam cycle get message “Needs prime” Has only happened recently. Any solutions?
  • Starbucks Master
  • 1,711 Answers
<b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt">We have a useful tip here in this link which can help you</span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"> </span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"><a rel='nofollow' href="http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime">http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime</a></span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"> </span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt">Good luck</span></b><br />
Posted on Aug 28, 2010
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Machine says ventilate
Hi
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. Also check the steam tip. This can get plugged and prevent the pump from priming.
Make sure that you water hardness is set on 4 in the menu. Descale more often than not enough and you machine will last a long time.
Oct 29, 2009 | Saeco Magic Comfort Plus Espresso Machine
Ventilate
HI
Hi
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the steam tip the message will not go away.
Oct 24, 2009 | Saeco Royal Professional Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
I have a Briel ED 132A Classic how do I prime the pump for the st
Sometimes the self- priming pump feature may not work due to a momentary "air lock" condition. If water does not flow from brew head, place a cup under the steam frother. Open steam control and turn the switcher onto the icon of the half-full cup until water flows from steam frother. Turn off steam control, as Espresso maker is now ready.
Manual is located here:
http://www.smithagy.net/BrielInstructionManual.pdf
Mar 15, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Saeco Digital Italia steam knob
Take off the top and you will see the steam valve, try to mount the parts again.
Best regards
/Mirran
Sep 09, 2008 | Starbucks Saeco Italia Digital Barista...
Overheat?
Typically it give the ventilate because insufficient amount of water/steam is comming through. A clog in one of the lines is usually the problem. This causes all kinds of headaches. There is nothing you can do so I suggest you do a search for an Authorized Saeco reapir center and have them do a service on it.
Dec 18, 2006 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
71 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
