Question about Sylvania LD320SSX LCD TV
My sylvania 32 LD320SS1 does not have VGA FOR COMPUTER how do i hooke up as monitor
Sylvania model LD320ss1 base unit Stand
Parts are not available from the manufacturer because they are assembled in China and the components are ordered for a run of complete products, not spare parts.
Try ebay for a non working set that has a base.
Try monoprice.com for a stand that fits your set.
Aug 27, 2014 | Televison & Video
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
I am trying to hook up my computer to my lc321ss9 b tv. I hooked it up to the VGA port and it says format not supported?
your screen resolution probably exceeds that of the tv.
try playing with your screen resolution.
May 02, 2011 | Sylvania LC-321SS9 32 in. LCD TV
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
Can i hook my computer to tv ?
Hello
You can connect your Sylvania LC320ss8 to a computer. There is a socket at the back of your TV to connect it with a PC via VGA cable. One end of that cable must be connected to TV, and the other end of the VGA cable must be connected to PC's monitor out jack.. You have to purchase on VGA cable for this purpose, and is available at most of the electronic spare part shops. A "mini-plug audio cable" also is needed to connect the audio from PC to TV. Its one end to be connected to PCs Audio Line Out jack and its other end to TVs PC in audio jack. Both Jacks can be located at the back side of the TV. After connecting it select the TV to receive PC signals according to its manual says. OK.
Jan 26, 2011 | Sylvania LC320SS8 32 in. LCD Television
Hook computer to tv
you can use the vga input with reg. vga cable and set computer to work from monitor to monitor. or HDMI if your computer has this hookup.
Dec 31, 2010 | Vizio L32 32 in. LCD HDTV
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
How do i hook my 32 inch sylvania model lc320ss9 to my pc
This set has a VGA input connector on the rear panel, so you can just plug in a cable from the PC to the TV. You can download a copy of the owner's manual and get more connection information at Sylvania's site here.
Jun 19, 2009 | Sylvania Televison & Video
How can I connect the tv to a pc. The 6632lg
on the back of your tv there will be an input marked VGA or PC input. connect your cpu(computer) to this input just like you do to your existing monitor. then use your tv remote to select pc or vga input as your source for video. mch
Mar 09, 2009 | Sylvania 6632LG 32 in. LCD HDTV
Sylvania LD320SSX LCD TV Logo
229 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
