Question about Kenmore 600 7962 Dryer
Kenmore 600 7962 Dryer- No power to machine at all (light doesn't turn on when door is open, will not turn on). When I have my hand on the back (silver-metal) panel when pressing the "ON" button, my hand gets shocked. I checked fuses to the outlet, and have taken the back panel off the dryer to see if there are any obvious shorts in the wiring.
  • pinkhams Aug 28, 2010
    I can't afford to pay somebody hundreds of dollars to come fix this. Don't care about risk as much as I do a solution. Not trying to be an idiot, but right now I'd rather feed my kids than have a dryer, so hiring is out of the question.
    I appoligize for sounding like an idiot here, Joe, but I simply don't have the money to hire somebody at this point. Does this sounds like it would be the thermal fuse?
  • 10,865 Answers
Hello. The fact that you are getting a shock has the potential to injure or even kill you. Something is amiss either within the dryer or with the wiring or the plug. Get a qualified electrician in to check this out and repair it. The fact that your dryer is not working is the least of your problems until your SHOCK hazard is repaired. This is nothing to take lightly. Please have this checked right away. J.
Posted on Aug 28, 2010
The door on my kenmore front loading washing machine is open but the lock is stuck in the on position
Turn off the electric to the dryer,the lock should open,close the door and turn electric back on, make sure the lock's not obstructed
Nov 13, 2014 | Kenmore Washing Machines
I have a Kenmore Elite Dryer model # 110 63012101 that is not wanting to turn on. It is getting power because the door light still turns on but the drier won't do anything. Are there fuses or a re
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing .
May 08, 2012 | Kenmore 63012 Electric Dryer
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
Hi , i have a Kenmore dryer special edition model # 110-8866291 stop working after i open the door while it running , did i blow the fuse ? please help .
its supposed to stop when you open the door,, close the door and try starting it up again, if it doesn't, its going to be one of 2 things,, the thermal fuse blew, they are located in the back of the machine or the door safety switch went out, you can check that by by passing it,, just jumper the 2 wires to it together and hit start , if you have no power at all to the machine, I'd check the thermal fuse first
Aug 23, 2011 | Dryers
The light does not go on and the dryer will not run?
If your sure you have power to the machine, and the light does not come on when you open the door, then you need to replace the door switch on the dryer.
Dec 21, 2010 | Kenmore 73932 Gas Dryer
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Kenmore 600 7962 Dryer Logo
156 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
