Question about Refrigerators
The missus destroyed the fridge door drink shelf , its a whirlpool WRX38RWH6 . thanks for any help
  • outtachoices May 08, 2008
    thanks
    i have put you guys as a favorite
    the missus says ta
    then she hit me
Get a new missus......
Posted on Aug 19, 2012
  • 828 Answers
A whirlpool dealer should be able to order the part you need short of replacing the whole door. Give them the model and serial number of your product. Whirlpool also provides a 800 help line which should be listed in your owners manual. Give the girl a break as things happen.
Posted on May 07, 2008
I need an owner manual for the whirlpool refrigerator with the model number ET14JKXDW10. Inside fridge leaking water
Water inside fridge usually due to blocked drain tube, clear with drinking straw and check door seal and clean condenser
May 09, 2012 | Whirlpool Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Condinsation in fridge
This is an indication that you have a bad door seal. Let me know, Thanks, Sea Breeze
Feb 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
How to remove the rear panel freezer
leave the unit off for a ewhole day with the door open. you are right that you may do damage when you pull off the cover. after the unit is defrosted there is sometimes coveres that you can pop off and behind them are the screws that have to be removed to check the drain out.g
Dec 21, 2008 | Refrigerators
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Hi where can I obtain spare parts for a whirlpool fridge model # wrx38rwh6 - I am after a bottom, shelf, vegetable crisper and big milk side shelf. Do you know the price? Thanks Tara
Check phone book for local part distributor or repair facility, most repair shops sell parts. also check links on this site for mail order.
J
Jun 12, 2008 | Whirlpool Refrigerators
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
