Question about Whirlpool ES5FHAXS Side by Side Refrigerator
Frost build up Problem with the Whirlpool ES5FHAXS Side by Side Refrigerator we have frost build up between the ice dispenser and the outlet in the door. at times the door will not close withou force. we then must "thaw" the frost. it will eventually build up again. any clues as to how to prevent his from happening? Also, Sears out twice, fixed it for a few months, they just aren't competent. -Robin, same question as somebody else asked earlier.
    Top Expert:
  • Whirlpool Master
  • 48,313 Answers
Check for door adjustment or problem door seals
Posted on Jun 23, 2017
  • 531 Answers
SOURCE: Amana SXD 22S2W -Frost on fins but not cooling.
you may have aburn out may be heater
Posted on Mar 31, 2009
SOURCE: fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Posted on Apr 29, 2009
  • 151 Answers
SOURCE: Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
Posted on May 14, 2009
  • 46 Answers
SOURCE: Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Posted on Jun 26, 2009
  • 48 Answers
SOURCE: freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Posted on Aug 24, 2009
Why is my ice maker getting frost build up?
The two most likely culprits are the defrost heater system (heater, thermostat, timer) or the evaporator cooling fan is not working. But also take a look at the speed your ice filler tray is filling, if the pressure is too high, then water can splash out and cause and ice/frost buildup.
Jun 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost buildup on area where ice comes out of the ice bin with frost also on the inside of door chute
The flap door where ice is dispensed is warped letting warm air into the freezer causing the frost build up. You must replace the flapper - a $5 - $7 part but not too difficult to replace. I find the flapper last only about 2 years and frost problem reappears. Forget about a "weak heater".
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
May 16, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ES5FHAXS Side by Side Refrigerator Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
