I have a Delonghi type Venice fireplace serial no 52013. Normally it has a nice flicker which goes up the back of the fire place and looks like a normal fire. Today the gentle flicker has turned to a very constant very fast flicker from the bulbs and no gentle flicker that goes up the back to look like a normal fire. I was told it might be the circuit board. Could you give me some advice or let me know someone that might be able to fix it please.
    New Friend:
Did you fix it as I have a Delonghi Venice electric fire which has just stopped working for no reason? There is electricity going to the circuit board but nothibg is working. Could this be a faulty remote control?
Posted on Nov 08, 2015
4 Suggested Answers
  • 9 Answers
SOURCE: Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Posted on Dec 15, 2007
meBNme
  • 334 Answers
SOURCE: hello i have proble with air conditioner and heater is a split system unit
What its telling you is that there is an outdoor "thermostat" that senses the outdoor temperature.
The system has found a failure on this area.
It is telling you to check the sensor to see if its actually the sensor thats bad, or something else.
Then its telling you to check the wiring and connection of the sensor to the control board for any loose wiring or broken connections, and to repair it if so.
It then says if niether of those two checks reveal any problems that the problem is the board itself and it should be replaced.
To answer the question, resetting it probably will not work.
There is a small chance that due to power surge, flickering lights, or just a fluke one time glitch that there is nothing rally wrong and resetting would work.
95% chance that is not so.
Posted on Dec 10, 2008
johnrodgers1
  • 80 Answers
SOURCE: Gas fire place does not turn on with the remote
you have no damper, it was removed to put gas unit in. chcek batteries in remore and in RECEIVER, receiver is usually forgot about it is insdie the bottom door more than likely, the fan only comes on when unit is up to temp, it has a heat sensor on bottom of unit, check wires on a gas valve for remore receiver as well, usually go on top and bottom screws
Posted on Feb 06, 2010
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Why does gas fire place fire goes out and comes back on after a few minutes ,until i turn it up higher.
Your thermostat has gone and is not telling the unit to switch back on when the temperature drops below the threshold. You are doing the job manually.
Dec 30, 2016 | Home
I need a phone number too call to order a remote
Start by providing the fireplace manufacturer name and model number of the fireplace. If you have the model number of the existing remote, please provide that also. It will be much easier to assist you if you provide as much detail as possible.
Feb 04, 2015 | Computers & Internet
Fire wont flicker on my electric fireplace
most of those electric fireplaces have a band of paper with holes in it that rotates around a light bulb this gives the illusion that the fire is flickering the motors that rotate that band of paper go out all the time its just a little electric motor you might be able to get one from the manufacture
Dec 07, 2012 | Heating & Cooling
I have no problem with the heater but was told they are recalling some for fire hazard reasons. How do I find out if mine is one of them??
Go on line to the Delonghi home site and normally they post info. on recalls etc.. Failing that contact your local Delonghi agent - they will know - make sure you have the model and serial number
Jan 08, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
I have an electric fire place. The blower is fine, however, the light that ulluminates the logs and makes it look like a real fireplace is out. How can I fix it?
I just repaired ours and it is quite simple,if it is the same type.First remove the front cover frame, then with a screw driver repove the clip at the top of glass,ease out the glass and lift up to remove.Remove the plastic logs and you look inside and you will see your burnt out lights,remove them, buy the same type and replace them, normally they are standard candleobra light that you can buy at any hardware store.
Nov 05, 2010 | Leisure HOMEPRIDE Electric Fireplace...
I have a napoleon wood fireplace, I just installed it in a fireplace. It seems like I can't get any heat out of it. I installed a cheminee liner up the cheminee. I think that the heatloss is going up the...
an open fireplace is not going to heat your house only 5 feet in front of the fire place. 75% of the heat goes out your chimney and burns the wood very fast. sorry to say but if you are looking for heat you installed the wrong unit!
Dec 14, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
FIRE GOES OUT AFTER AWHILE
Hi clean pilot light check out thermocouple might need new one
Nov 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
201 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
