Question about Maytag Dryers
Maytag legacy series dryer starts and spins but will stop spinning after a few minutes
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
Maytag Legacy Series Electric Dryer
May need a new timer, I had to replace mine, easy job if you watch the video online.
Jul 08, 2013 | Maytag Legacy Series Top Load Washer
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Has stopped in the drain spin cycle. If i unpluge
i HAD TO REPLACE THE TIMER SELECTOR, THIS CORRECTED THE PROBLEM
Feb 13, 2010 | Maytag Legacy Series Top Load Washer
Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Dryers Logo
252 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
