Question about Video Cameras
Hiya i have a old sanyo camcorder with no usb connection on it can i still transfer the tape to vista what will i need to do this
  • 4,234 Answers
The only way to do this is to use video capture software and an input card that has a yellow video input.
Dan
Posted on May 07, 2008
Can you please tell me why when i try to import vidoes using picture motion browsing i am getting the message Cannot find source media for importing,
You might be connecting the Camcorder using USB interface. Picture Motion Browser Cannot be used for transferring videos from tape camcorder (mini DV in your case) using USB interface..
Operating System also matters..
If you're using XP OS, you can install the driver from supplied CD and use Windows Movie Maker to transfer the recordings using USB interface.
Vista, Windows 7 - You need to use i.LINK or A/V interface to transfer the recording. When using i.LINK with Vista, you can use the Picture Motion Browser software.
I think this will definitely help you to connect the Camcorder..
Dec 03, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Panasonic PV-DV953D video transfer to PC
Did you put the camcorder in the VCR mode and make sure it is turned on, so you can transfer the video?
Jul 30, 2008 | Panasonic PV-DV953 Mini DV Digital...
Cant instal drivers
usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
I cant seem to be able to transfer my recordings to a DVD recorder on my computer The video recorder is a Sony DCR-TRV22E.My computer is PRYON. PRY-i922vp
If the Computer is having Windows Vista installed on it then it's required to use a compatible i.LINK or Firewire cable to connect the Camcorder to the Computer.
Once the connection is established, you can use Windows Movie Maker to transfer videos from the Camcorder to the computer. Make sure that the Camcorder is set to the "VCR/VTR" or "Play/Edit" mode and the tape is playing in the camcorder before importing the videos to the Computer.
If you're having Windows XP on the Computer and using USB cable to connect the Camcorder to the Computer then it's required to install the USB streaming driver and the USB driver for connection on the Computer before you can establish a successful connection between the Computer and the camcorder for transferring videos.
You can install the USB streaming driver using the supplied Software installation disc.
Nov 07, 2009 | Sony Handycam CCD-TRV67 Camcorder
My Macbook Pro also did not detect the connected GR-DVP9AG
The old Camcorders (which using tapes) need to use firewire 1394 connection (4 t0 4 or 4 to 6) to transfer video to PC/ Mac.
Sep 21, 2009 | JVC Cybercam GR-DVP9 Mini DV Digital...
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Compatibility with Windows Vista
you cannot use usb connection on vista with this camcorder if you want to transfer videos from tape. use a firewire or an ilink cable and windows movie maker to capture videos. no drivers needed.
Mar 14, 2009 | Sony DCR-HC42E Mini DV Digital Camcorder
I cannot transfer videos to my computer with my Sanyo Xacti VPC-CG6
After the USB cord is connected, a menu will popup on the camera. The camera needs to be told you want to transfer files with the usb rather than use the camera as a webcam for example.
Selecting USB Connection / Card Reader on the camera should allow you to access your files on the camera.
You could try removing the memory card from the camera and using an external usb card reader on it.
Oct 07, 2008 | Sanyo VPC-CG6 Digital Camera
How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
Aug 24, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Video Cameras Logo
147 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
