Question regarding audio connections Akai 30" LCD TV
Trying to connect a dvd player to this TV for a friend. The video connections are on one side of the TV, scart, composite, s-video, component.On the other side are the following connections PC, headphones, audio in 1/out (R/L), audio in 2 (R/L). The scart is being used by a PVR and the composite by a freeview box. Have connected the dvd via the s-video. The pictures ok but can't figure out how to get the sound out of the dvd. The PVR sound is ok being carried in the scart lead. The freeview box sound is ok and connected to audio in 2. The dvd only works in the audio in 2, ie have to disconnect the freeview box audio cables and plug in the dvd. Can't figure out how the audio connection ties up with the video connections. On my own TV each video input has it's own associated audio input. Any help appreciated. model LM-H30CJSA
  • bargepole May 09, 2008
    Thanks for the ansers,
    Have bought component cable and connected dvd via that as it appears to use the audio in 1 sockets (which were free) for the sound.
I cannot get sound from Sky HD using the DVi channel. I have used a DVI - HDMI cable and also ued external audio from the Sky HD box to the TV. The output from the Sky HD box is working as I have connected this to a HiFI amp and speakers. Ay suggestions... the Ryder Cup is starting this week!!!
Posted on Sep 16, 2008
How to connect External Speakers (with Amplifier) or Headphones to Akai LCD 32LW7?
Posted on May 09, 2008
  • 476 Answers
If either of your PVR or freeview boxes have two scarts, you can route one through the other.
Connect the PVR to the VCR/DVD scart of the freeview box, or connect the freeview box to the VCR/DVD scart of the PVR.
You can then use the red/white audioleads to connect to the DVD.
Alternatively you can route the DVD through the PVR or freeview box.
  • 558 Answers
A switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
Posted on May 08, 2008
How connect an LCD tv to hi fi when dvd player is connected in hdmi to THE LCD TV?
you need to see if you have audio out on the tv, if so! you need to go from audio out on tv to input on your home stereo! everything played on tv will work through home stereo! if no sound, you have to go to menu on tv and into sound and change TV's output from internal speakers to external output! hope this helps!
Jun 12, 2017 | Akai LCT2715 27 in. LCD Television
Run the signal from a AKIA DVD Lcd TV to a Projector Screen TV
from the back of the tv player it will connect to the projector on the big screen usig rca leads
Jul 30, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
How do i put a DVD player on TV
HI, your video Connect your Audio cable ( white-red) output from dvd to tv in. Then connect your video output ( yellow) to tv video in. If you have Pb Y R in /out , just connect them accordingly to enhance the video.
Regards
Jan 23, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Aug 08, 2010 | Sony Televison & Video
I do not know how to connect my DVD to my 42 in
Tries use a RCA cable plug 2 connections ports holes red,white audio out input connected ur DVD player,connnect the other side the RCA to TV audio in input.Use a S-Video cable for video connection to get video.If u have the new version of a DVD player just use a HDMI cable plug one end to the DVD player the other to the TV.
Dec 15, 2009 | Vizio L32 32 in. LCD HDTV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
No Audio
The yellow, red & white terminals are composite out (old RCA connectors). Yellow is video. Red is right side audio out (line). White is left side audio out (line). You can connect them directly to any TV that accepts composite input. (i.e. Match the colors).
Feb 25, 2007 | Akai DVPS760 DVD Player
Televison & Video Logo
501 people viewed this question
Top Televison & Video Experts
