Question about HP LaserJet 2100tn Printer
Opening the an HP Laser Let 2100 Printer
There was a paper jam in my printer yesterday. I am a guest at this house, and I can't find the manual. Could you tell me how to open the printer to get the jammed paper out.
I found the manual on the manufacturer's site, and I just followed the instructions. Thanks!
Posted on May 08, 2008
How to clear a paper jam in my printer?
  1. Turn off the machine, and unplug the power cord of the machine from the power supply.
  2. Open the paper output cover. ...
  3. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  4. Hold the jammed paper with your hands.
  5. Pull the paper slowly not to tear it, then pull the paper out.
to know info SAF 2507 pipe fittings
May 20, 2016 | HP PSC 950 All-In-One InkJet Printer
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
1.1
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
2.2
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
3.3
Gently pull on the jammed paper. In many cases, it will come out easily.
4.4
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
5.5
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
6.6
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
Cannot get at paper jammed in printer. How do I do this
You this manual to clear your paper jam.
Directly go to page No. 91 it explains how to open the door and paper tray to clear the paper jam.
http://static.globalcomputer.com/pdf/Brother-HL-2140-Mono-Laser-Printer-Manual.pdf
Regards
Rudra.
Oct 11, 2010 | Brother HL-2150N Laser Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
Paper jammed and now will not turn on
Pull out the laser cart and see if you can locate a sheet from that end.
May 31, 2009 | HP LaserJet 2840 Printer
Hewlett packard laser jet 2100 model c4170a
Try removing the toner cartridge and re-install it again then recycle the power.
Jan 11, 2009 | HP LaserJet 2100 Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Paper Jam
Look into the configuration settings of the printer.. there should be something like disable message on something...
if you can't find it.. try to rest your printer.
Turnit off -- then press Go (or something similar) button while turning it back on.
Jul 18, 2008 | Xerox DocuPrint N2025 Laser Printer
Problem. Help please
If the light is steady, the manual says possible problems are
  1. it is out of paper
  2. paper is jammed
  3. one of the doors is open
  4. the toner cartridge is missing
Jul 17, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2100 printer
I want to reinstalled Laser Jet 2100 printer so what can i do
Apr 16, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2100tn Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
