Question about Bunn NHB Coffee Maker
My NHB bunns coffee maker leaks from the bottom when brewing. Is there an easy fix?
  • 189 Answers
If you will call Customer Service at 800-352-2866 with the model and code date, we will be able to help you resolve this issue.
Posted on Sep 13, 2010
Bunn nhb disassemble
Most likely is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
Apr 23, 2014 | Bunn NHB Coffee Maker
My bunn nhb makes a continuous "boiling" sound even after coffee has brewed.
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
Nov 26, 2011 | Bunn NHB Coffee Maker
Bunn NHB model leaks water out of the bottom
Please call customer service at 800-352-2866 with the date code from the bottom of your brewer. We will be happy to assist you with this issue.
Dec 31, 2010 | Bunn NHB Coffee Maker
My Bunn NHB is about 2 1/2months old and when I flip the lid to start brewing, is takes about 10-12 minutes to brew. It is not limed up. Problem?
Did you do the vinegar cleaning and deliming of the machine? If this didn't correct the problem, then please call customer service at 800-352-2866 with the model and date code off the bottom of the machine and we can replace it for you.
Nov 17, 2010 | Bunn NHB Coffee Maker
My Bunn coffeemaker NHB is leaking from the bottom onto my counter. Can this be fixed?
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
Apr 28, 2010 | Bunn NHB Coffee Maker
HAVE BUNN NHB COFFEE NOT HOT ENOUGH ON BREWING
I work for BUNN. Please call our customer service team at 800-352-2866 so they can talk thru what's going on and solve this for you.
Jan 22, 2010 | Bunn NHB Coffee Maker
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Water leaks out of holes up under resevoir.
Use a Torx T-9 tamper resistant screwdriver to remove the screws on the bottom of the coffee maker.
Your plastic tube has probably come loose or is leaking. Carefully re seat the plastic tube over the metal tube using the metal spring compression clamp.
Jan 09, 2009 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
202 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
