Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire modle number fex831cso will not agitate or spin when it is moved to spin from wash the water pump will start for five seconds then it will turn of with out spinning. then after about five minutes it will try again. I can move the agitater by hand
the dr
  • 447 Answers
SOURCE: whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
eandlfan
  • 9 Answers
SOURCE: Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Posted on Dec 23, 2007
  • 90 Answers
SOURCE: Admiral Washing Machine not spinning
Make sure the safety switch that the lid operates is getting pushed down. Use a popcicle stick or non metalic object to push the switch in and try to get it to spin. This switch goes bad alot. It is in a wet environment. You will normally hear or feel a click when the switch is depressed. If not, use a putty knife or butter knife to push the top retainer in that are located at the front outer corners in the gap just where the top of the machine meets the rest of the unit. While pushing in you should feel a slight resistance but it should spring in and allow the top to lift up. Make sure to unplug the unit first.... Find the switch and unplug the two wires from it and use something like a paper clip or small wire to connect the two wires together. Let the top set back down, doesn't have to snap down and try to get it to spin again. If this works then the switch is bad... There are plastic parts on some machines that push this switch when the lid is closed that get broken off without you noticing until it just doesn't work right..
Posted on Feb 10, 2008
ezed51
  • 7 Answers
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
Posted on Jun 01, 2008
jsrock516
  • 5911 Answers
SOURCE: Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Posted on Aug 06, 2008
Speed not changing in delicate mode fex831cso
The spin cycle is not going to change it is how strong the agitation is
And how hard it soins
Jun 05, 2015 | Frigidaire FEX831CS Top Load Stacked...
I have a stackable washer and dryer from Frigidaire model# FEX831CSO. The washer will not agitate or spin but will drain. What might be the problem?
Good Afternoon Sarah, thanks for your post!
From the information you have provided the washer on your Frigidaire laundry center will not agitate or spin and will drain. This sounds like a possible issue with your motor or belt. In order to pinpoint the issue with your washer you may need to disassemble the washer and test each component for electrical issues and cosmetic damage. This is not a simple DIY job and I would recommend you speak with a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Apr 20, 2015 | Frigidaire Washing Machines
My Frigidaire stackable washer/dryer is having a washer issue. It will agitate, but will not pump out the water. When I manually move the timer switch, it will not spin at all. I bought a new timer...
Spinning won't start until the water level is low enough. Yup, it sounds like a pump issue. Check to see if the pump is not blocked by something. Get to it, my man. At Warp speed!
Sep 13, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Model FEX831CSO washer doesn't work.
The pump that expels the water may be clogged or have a broken gear they are plastic. Thing like baby socks find their way into them and the clogged or break. New pump will be about 60 dollars if that is the problem, and someone to take old one out and put new one in. The diagram is usually somewhere on inside wall of washer taped, it includes a trouble shooting chart and part numbers.
Jan 19, 2018 | Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
