Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP
When i start the lawn mower i sounds like its flooding and it has oil and smoe coming out of the muffler what could be he problem?
I dont know but i got the same problem.
Posted on Sep 03, 2010
A lawn mower that gas comes out of the exhaust.
It sounds like the float in the carburetor is stuck in the open position.This will allow fuel to flow through the carb and out the muffler.
May 04, 2015 | Garden
Why wont my mower start and gas comes out of muffler
carb is flooding out ether bad plug or your carberator needs rebuilt
Aug 25, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Push mower has oil coming out the muffler after turning it up on its side
This is normal when you tip an engine on it's side . They recommend you don't turn it on it's side as it causes the oil to flow to the valves and pistons. It also is hard to start as the oil gets in the Spark plug stopping it from firing Flooding will be a result as well. You can turn the mower over a little but not completely on it's side to clean
Jul 17, 2014 | Briggs & Stratton Garden
Gas is flooding out through the muffler in my push mower
sounds like the needle valve in the carb is not seating replace them and the oil
Jul 05, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a 4.75 horsepower push mower and there is oil coming from the muffler. What is the cause of that?
SOMETIMES IT IS AS SIMPLE AS A PLUGGED AIR CLEANER, IF YOU LEAVE IT PLUGGED LONG ENOUGH YOU CAND RUIN THE CYLINDER CAUSING THE OIL FLOOD. IT MAY ALSO BE THE EXHAUST GUIDE ITSELF HAS WORN SO BAD THAT OIL GETS BY, BUT THE ENGINES USUALLY DO NOT RUN AT THIS POINT. tHE FIRST THING TO CHECK IS THE PROPER OIL LEVEL, DO NOT OVER FILL.
Aug 02, 2011 | Briggs & Stratton Briggs Stratton...
Oil started to come out of the oil filter and muffler after changing oil
sounds like you over filled the oil let it set and recheck level, also never tip it to the muffler side, always tip to carb side to change oil, service blade. if oil is o.k. then pull spark plug and clean the oil off it and try to start , It will smoke like crazy till it burns the oil off muffler!
Apr 18, 2011 | Troy Bilt 5.5hp Self Propelled Mower
My mower will start but not run. Oil and gas is leaking from exhuast and filter. What could be wrong?
if the filter is a sponge filter then it's suppose to have oil in it(helps trap dirt) and if your getting gas out of the muffler then the engine is flooding when you try to start it..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
Old old lawn tractor It starts but does not
NOT A EXPERT JUST TRYING TO HELP,,,SOUNDS LIKE YOU NEED TO CLEAN CARB. OR REBUILD IT,,, HOPE THIS HELP
Oct 08, 2009 | Garden
Push mower won't start. Oil coming out of muffler
Your motor is pooched. Oil is not supposed to come out the exhaust. It indicates a worn out motor or something broken inside like a piston or compression rings. Or possibly someone has put half a gallon of oil in it instead of half a quart and it's well overfilled?
Aug 31, 2009 | Garden
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP Logo
176 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
