Rear projection screen 152cm lg going yellow
Hi i have a 152cm lg rear projection tv and the screen over the last 4 months has started in one area to go yellow and is now spreading over screen and also has blue ares on the sides of the screen.
  • wally11 May 07, 2008
    please help
  • shannysps3 Oct 20, 2008
    I have the same problem ....Like little blue stars ..now yellowing...
  • 4,234 Answers
I am guessing that this is an LCD projection set, Please post the make and model so I can confirm. In the mean time, if it is an LCD, there are 2 possiblities.
1) The lamp may require changing. Sometimes the inner surface deteriorates because of the heat.
2) The "light engine" requires replacement as the heat and light have started to burn the LCD surface. This burning starts to show up as a yellowing usually onm one side first and spreading to the other side.
Dan
Posted on May 07, 2008
Replaced lamp from Sony in January. In the last month or so been noticing a large yellow spot in the middle of screen. My TV is a Grand Wega LD Projection TV Model No. KDFE42A10, Serial #9507132.
your optical block is failing. Sony has a program for replacing them if you want, or they will offer you a new TV. call this number 239-768-7604 and tell them what you TV's symptoms are and they will get you started
Jun 12, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
Yellow spot in middle of screen
We have the same exact problem with the same TV. We've only replaced the bulb once about a year ago. Don't know if it had anything to do with the fact that we now have a large yellow circle in the middle of our screen, which is about 7" round.
We only noticed the yellow mark about 4 months ago.
Hopefully someone will have a solution for us that doesn't cost an arm and a leg. Paid $2100 for this set and are a little disappointed.
Nov 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
DEVOLPING YELLOW LINE ON SCREEN
The yellowing of Sony’s KDF-60WF655 rear projection is a problem with the SXRD optical engine. This turned out to be a big problem on many of the SXRD TV's. Sony actually had a class action lawsuit that covered the optical engine for 5 years. My unit was replaced in June of last year (2009) about 1 month before the coverage ended. My unit had a bad yellow streak on the right hand side. Sony no longer covers the cost of replacement, as the class action suit has now expired. Sorry for the bad news. Its not clear if a new optical engine will suffer the same fate after a few years. Sony’s rear projection TV's are amazing and the picture rivals many of today’s LCD's and Plasma's. Any authorized Sony Tv repair shop will no exactly your problem and will be able to give you a fixed price to repair.
Hope this helps
Apr 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Model: 152cm LG rear projection, 3 yrs old, for last 12 mths the screen has been going cloudy blue in patches and now the whole screen is blue, I can still watch it but not much colour in it . Can you...
Could be dust around the optical block. Could be that the blue LCD panel is going bad from being heat stressed. The blue panel is closest to the lamp so it gets the brunt of the heat from it. Call Sony and complain. They know about this design flaw and have been replacing light engines even out of warranty on some models.
Nov 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Yellow area on screen
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident.   Hope This helps!
Jan 24, 2009 | Panasonic PT-51HX42 51" Rear Projection...
60" LG Lcd Projection TV
ok u could have somthing on the lcd srenn and thta is y u have a yellow spot what i would do first is pull out the unit and look at the luc screen and buld to see if u have somthing on it i could be a small pice of papaer or anything it is best if u look at it thru the lens on the inside on the tv when u have it on because u can see i t better i hope this hps marty
Oct 12, 2008 | Hitachi 60V500 60" Rear Projection...
Yellow brush marking on Screen
Your problem is with the blue color,maybe some dirt is sitting on the face of the blue crt and is being projected bigger to the screen,you should try cleaning the face of all 3 tubes,if you familiar with tv service this should help,be careful when removing the back and make sure the set is unplug when you do the cleaning.Let us know how it goes.
Oct 06, 2006 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Lcd rear projection fixed pink and yellow shadows on the screen
you can't do anything about this TV. Theres no such thing as a LCD rear projection television.
Sep 01, 2006 | LG RU-52SZ51D 52" Rear Projection...
Computers & Internet Logo
408 people viewed this question
David Payne
David Payne
