Question about Husqvarna Garden
I need a repair manual for a Husqvarna LGT2554
2 Suggested Answers
  • 3698 Answers
SOURCE: I have a husqvarna lawn tractor LGT2554 quit pulling do this mean that transaxle need to be replaced or a part to fix?
Most likely "part to fix"
www.husqvarna.com/us/support/
Posted on Jun 24, 2014
Is there a safety mechanism / cable on Husqvarna LGT2554 that will not allow blades to engage if it runs out of gas while mowing
None. The only safety switch that prevent blades from engaging is the reverse switch but that will just kill the engine.
It is more likely that the deck drive belt has came off only of the pulleys.
Oct 19, 2014 | Garden
Need Husqvarna LGT2554 drive belt diagram
Should be a belt install on the bottom of the left footrest but just in case it is gone.
Jul 21, 2014 | Husqvarna Garden
I purchased an LGT2554 lawn tractor in the spring of 2010 , good mower but the front wheels keep falling off, does NOT have bearings but only bushings and for the price should have wheels with integrated...
None of the AYP mowers i have seen have proper bearings in the wheel, they all have a sintered bush with a grease nipple to lubricate it, as long as they are lubricated they give a reasonable service life, i am sure there are after market wheels out there with a better bearing but there is a fair cost for this.
Aug 18, 2013 | Husqvarna Garden
I have a husqvarna lgt2554 mower ... wont start, whines. Makes the whiney sound when I try to start it with the key or when I try to jump it by the solenoid. Does this mean its a bad starter??
It could well be the starter motor, but you need to check the gear on the end of the motor, it maybe the teeth half worn, this part will be a lot cheaper than changing the complete motor.
Mar 11, 2012 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
I have the Husqvarna LGT2554, with les than 30 hours. The drive belt slips off all the time. I have put it on 5 times and nnow purchased a new one and just put that on. I did 4 swipes and it slippped...
THERE SHOULD BE GUIDES, THE LOOK LIKE LONG BOLTS THAT ARE NEXT TO THE PULLEY, THESE NEED TO BE CLOSE TO THE PULLEY TO HELP KEEP THE BELT ON WHEN THERE IS DECK MOVEMENT ,. MOWER OFF , DECK DOWN AND ENGAGED.. SIT THERE AND STARE AT THE BELT AND PULLEYS TO MAKE SURE THERE ALL LOOK LEVEL AND TRUE, THE TENTIONER BRACKET CAN GET BENT EASILY. THIS IS WHAT I HAVE FOUND
Jun 17, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
When I turn key on I get nothing. No lights , no engine hours, no nothing.
If the battery is fully charged you most likely have a blown main fuse. If you can't find it send me the model of the mower and I will try to assist you. Regards Phil.
Apr 26, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
New Lawn mower cutting off after 40min of run time
Sounds like you have found a possible solution to your problem. If the cap is not able to vent, it will create a vacuum. If this happens again, try just loosening the cap and see if the mower will run before filling it up again.
Sep 30, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Seems as though the fuel filter is getting stopped-lgt2554
Remove the gas tank and clean it out, look for signs of water and or dirt in the tank also look for a pinched fuel line between the tank and the carburetor
Sep 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
1998 Husqvarna 265RX Brushcutter Service/Repair Manual
Fixya does not have the manual I'm looking for.
Nov 23, 2008 | Husqvarna Garden
Garden Logo
202 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
