Question about Cycling
Steering is loose - Cycling
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
Tighten the bolt atop of the forks. ie/ if you sit on the bike there will be an octaganal bolt head looking at you as you look down at the front steering wheel. just please make sure when you do the ltter, the front wheel is inlintne with the handle bars.
vote please
Posted on Aug 28, 2010
What is a CV joint?
A wobble in the steering is more likely to be one of
- loose wheel nuts
- loose hub nut
- worn steering tie rod outer joint
- worn steering tie rod inner joint
- loose steering rod universal
- worn steering knuckle ball joint
Out of these a worn or loose steering tie rod joint is most likely. If you can, jack the front of the car up and rest it on axle stands, NOT just on the jack, then have one person shake the front wheel back and forth while holding it at 9 and 3 o'clock, while another holds the steering wheel still. Then look at and feel each joint to see if you can locate the looseness.
Jun 27, 2014 | 1997 Toyota Camry
Steering wheel loose on a 1996 Honda
Hi there are several things that can make your steering wheel
feel loose. Check that the universal joint that connects to the steering rack from inside the car are not loose by moving the steering up and down, it could also be the steering column bush,(only if the wheel go up and down side ways) check
also the tie rod ends by jacking the car grab the front and back of the wheel and shake in and out to see if you have any loose.(always secure the car on stands ) other than that it could be the rack and pinion steering mechanism that would need to be changed.
Jun 18, 2014 | 1996 Honda Civic Steering Wheel Ring
My steering wheel wiggles
You could have an out-of-balance or out-of-round condition on the front tires, but similarly it could be something more serious
-loose front wheel hub
-worn front suspension joint
-worn steering tie rod joint
-loose steering box mounts
-loose steering column u-joint
-loose or word steering wheel attachment
Oct 31, 2013 | 1991 GMC Sonoma
Verry loose steering on a 96crown victoria police interceptor front end parts r ok . what can i do to fix it
Then you either have a defective steering rack or you have a loose steering shaft rag joint, check both.
Jun 25, 2012 | Cars & Trucks
How to tight up the steering 1500 silverado 2002 4x4. The steering feels loose.
Before messing with the steering box check all tie rod ends, pitman arm, king pins.
Have someone slowly move steering wheel back and forth while you watch for excessive movement in you components.
Worn tires, underinflated tires will also give a loose feeling
Loose lug nuts
steering alingment
good luck
May 20, 2010 | 2002 Chevrolet Silverado
Loose steering in 04 trailblazer
YOU COULD WORN WHEEL BEARINGS TIE ROD END LOOSE OR WORN OR YOU HAVE A LOOSE STEERING GEAR.THESE ARE YOUR POSSIBLE CAUSES LOOSE STEERING.
Mar 03, 2010 | 2004 Chevrolet TrailBlazer
I have a 1981 Corvette with tilt steering wheel. The steering wheel has started flopping like something is loose in the steering column. Whats going on? Thanks Jim
You must remove the steering cowl below the steering wheel and see what is loose, broken or worn. It more likely to be a loose bolt, in which case just tighten it and refit the cowl.
Hope that helps
Jan 15, 2010 | 1981 Chevrolet Corvette
I have a 1984 jeep cj7 and it is having trouble turning, it feels like it is slipping and wont turn, like something is not catching, can anyone help
1. THE STEERING GEAR SHAFT ADJUSTMENT TOO LOOSE OR SHAFT AND OR BUSHING BADLY WORN 2 .EXCESSIVE GEAR WORM END PLAY DUE TO BEARING ADJUSTMENT 3.STEERING LINKAGE LOOSE OR WORN. 4.FRONT WHEEL BEARINGS IMPROPERLY ADJUSTED. 5 STEERING ARM LOOSE ON STEERING GEAR SHAFT. 6. STEERING GEAR HOUSING ATTACHING BOLTS LOOSE. 7.STEERING ARMS LOOSE AT STEERING KNUCKLES. 8.WORKING PINS OR BUSHINGS. 9.LOOSE SPRING SHACKLES.THIS IS 9 POSSIBLE CAUSES THAT WILL CAUSE STEERING TO BE TOO LOOSE.
Nov 10, 2009 | 1984 Jeep CJ7
03 supercrew f150 steering
check the steering linkage of the front end for loose components, most can be checked with the vehicle on the ground.
Also , check the Intermediate Steering Shaft for play, this runs between the steering gear box & the lower part of the steering column. it has an expandable section with 2 overlapping shafts that can wear & become loose with age & driving
Oct 15, 2009 | 2001 Ford F150 Styleside SuperCrew
Alot of play in steering wheel and power steering is completely out. Is there any way to repair theproblem or do you think I need to replace both?
look for loose steering gear shaft adjusted too loose or shaft bushing worn. steering linkages loose.wheel bearings improperly adjusted.
Apr 28, 2009 | 1981 Ford F 150
Cycling Logo
73 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
