Question about Nakajima Office Equipment & Supplies
How do I remove the bottom of my AX 60 model so that I may at least spray the keys and hope they would stick LESS. What should I use to Lub. the keys? Please advise Psimons@new.rr.com Help
  • Nakajima Master
  • 3,594 Answers
When you say stick I assume that you mean they go down but won't enter. If so what you need is a new contact pad that is sandwiched in side the keyboard. Not for the weak of heart.
DickyO
Posted on Aug 28, 2010
The key will not turn in the ignition the steering wheel is not locked.
Is your key worn out? If it is have a new key made. If key is fine spray some lube into ignitio key cylinder. Use a nozzle to get as deep as possible into cylinder cavity. Then let lub sit for a couple of hours. After, insert key and pull up, down and to sides until it releases. If it does not release you will need to pull out cylinder and lub all tabs or just replace cylinder.
Feb 07, 2016 | 2001 Pontiac Grand Am SE
Keys are locked in the ingnitition and wont start
To remove your key: look at the plastic shield underneath the locking cylinder. There will either be a hole there OR an outline of a hole there. You can stick something thin in there, then turn your key out. IF there is no hole, just look for the outline of where the hole should of been. Just drill it out, be careful as the plastic is thin.
May 01, 2014 | 2004 Chevrolet TrailBlazer
Engine stays running ignition turned off
What is going on is that there is a rod that moves to one position are the other when you turn the key over time corrosion can cause it to stick . If you have a friend that nose about cars have him spray some white lub on it that might help with you problem.
Feb 18, 2014 | Dodge Cars & Trucks
Key will not go into the ignition! I believe it is the dust cover that got bumped and will not move back for the key to slide in. How can I fix. My car is stranded at work! I have read on websites to...
that is the only way to get u going push the flap away and spray some lub like a Q20 or DWf that cleens and lubs cyl lock to get the flap loose,its normally just dirt in the lock.hope u come rite
May 21, 2011 | 2008 Volkswagen Jetta
My 89' pontiac firebird formula's ignition switch is becoming harder to turn. Its almost like it is tightened up. It is alot tougher to turn. What should I do?
Before replacing it try spraying Wd40 directly into the key hole to lub it up.
Spray it good and do all your key locks while you are at it.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | 1989 Pontiac Firebird
I have a 91 barina, it starts fine and idles and runs fine but it cuts out after 30 secs, what's this?
I think maybe the electorinic choke is sticking.........Spray with the lub of your choice and run some injector cleaner of your choice..................Hope this helps.
Aug 14, 2010 | 1991 Suzuki Swift
The front brakes on my suzuki ax 100 are seized, how do i free them, im a car mechanic and dont no much about bikes, its been parked for a year hense stiff brakes, any sujestions are much appreciated
TRY REMOVING THE BRAKE CABLE AND SOAKING IT IN AN OIL BATH OVERNIGHT.
IF U CAN DO THE SAME TO THE WORKINGS OR SPRAY WD40 ETC THIS WILL UN STICK THE WORKINGS.
HOPE THIS HELPS.
BEFORE OILING GIVE IT A GOOD CLEAN WITH PETROL OR GUNK.
Dec 28, 2009 | 2001 Suzuki AX 100
DV-S555 wont always open
I sounds as if the guide tracks on each side are sticking. Be vary careful and put a little bit of tuner cleaner and lub on the tracks and this will usually fix the problem. Do not spray it into the tray for it may mess up your lens. Hope this helps.
Jan 07, 2009 | Onkyo DV-S555
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
