Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE 7400AYW is squeaking bad. Not sure, could it be a rear drum bearing grinding on the roller
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Aug 29, 2010
Loud Squeaky Performa Dryer Mod# PDET910AYW. I am guessing I need a rear drum bearing kit, perhaps as well as the felt pad/glide? For some other models, like Frigidaire, it looks like they sell the...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Our maytag neptune dryer is squeaking. Can u please tell me the part needed? thanks
the most common problem on this unit is the rollers, one sits above the heater and the bearing dries out. I provided you with two links one where you can purchase the drum rollers you need two, the other link explains how to access the dryer to repair it.
Click Here Drum Rollers
http://www.appliancerepairlesson.com/2011/01/29/washer-and-dryer-atlantis-neptune-access-2/
Good luck with you're repair!
Mar 05, 2011 | Dryers
My maytag atlantis dryer is making a loud squeaking noise. sounds like metal on metal. possibly a bad bearing? any ideas...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 02, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We've got a Maytag MDE6000AYQ dryer that we love. It started squeaking two loads ago. It would squeak off and on during the cycle. This next load seemed to squeak worse, so I'm worried to use it any...
The squeak is most likely from the drum support rollers or the drum bearing. If it's the rollers, they're fairly easy to replace and often a drop of lubricant will solve the problem. This is just one supplier of such parts:
http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drum+Bearings+and+Felt+Drum+Seals/default.aspx
Jun 21, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Makes a loud squeaking noise when drum is turning
The felt on the front of the drum is probably worn out or the bearing on the rear of the drum is getting bad.
May 05, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
When the dryer is running it is really noisey. We should have returned it but didn't
Sounds like something is caught between the drum and dryer (inside) or the drum bearings are going bad. Normally sounds like a squeaking then get to a grinding noise (not good)
Aug 31, 2009 | Dryers
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
313 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
