Question about InFocus LP70+ Multimedia Projector
How do i connect a macbook to an infocus lp340b?
Have Infocus X2 projector. When on a dark shadow line appears down the left side of screen. Could it be a bad lamp?
no it is not lamp problem. it must be light tunnel problem.
after lamp there is tunnel for light travel, made from 4 pieces of mirror.
this tunnel is glued. glue tend to break in time so the tunnel is no longer doing its purpose.
open this part of projector, there should be 2 little screws holding it. repair it by reposition mirrors and glue them from outside by little drop of temperature resistant and elastic glue. that's it !
Oct 03, 2010 | InFocus Projector Lamp for LP340, LP340B,...
I only get a blue scree on my Infocus 340 so therefor I cannot see the images well.
give more details , when you get blue picture ?
blue screen is indication that no signal is coming to projector so check your cable and try different connection, there is svhs and dvi input, try both.
Apr 17, 2010 | InFocus Projector Lamp for LP340, LP340B,...
I have the same issue minus the clicking
check the lamp for bulges, black spots, or fogging. if that's ok, check the colorwheel. if that doesn't spin, the lamp won't light. if they are ok, replace the ballast.
Sep 30, 2009 | InFocus SP-LAMP-LP3F Projector Lamp for...
In focus LP340B
Hey scottydogg, not much inormation there, have you tried to download software from the actual compnay itself, and then install it to your pc, and then go from there, nearly all of the big companies, do allow you to download software in relation to a product you have purchased???
maybe put a little more inforamtion in your post.
Hope you get it sorted :-)
Feb 29, 2008 | InFocus SP-LAMP-LP3F Projector Lamp for...
Projector will not fully startup
the colorwheel is bad. and what's worse, you can't get parts for the lp340 anymore.
Dec 01, 2007 | InFocus SP-LAMP-LP3F Projector Lamp for...
InFocus LP70+ Multimedia Projector Logo
117 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
