Question about Kodak EasyShare Z650 Digital Camera
Not reading any memory stick i put in - Kodak EasyShare Z650 Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 29, 2010
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
I have a sony Memory Stick Pro Duo as a size of 8gb. I had a PSP that I used the memory stick, and I sold the PSP, but kept the card. None of my computers can read the memory stick, and I don't have a...
You can get universal card adaptors, just make sure its compatible with your memory stick.
You can also get USB adaptors, put you card into the adaptor the plug the adaptor into a PC.
Have a search on ebay, that should give you a few ideas.
Nov 19, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Hi, I can view the pictures of a memory stick on my camera, but when I put it in the sleeve and insert it in the computer, the computer can not read the disk. I have also used the USB wires hooking the...
possibility: the memory card is not formatted in a way that your computer to recognize it.
give this a try...
*format the memory card first (FAT32 or NTFS) using your computer
*put the memory card back to your cam, then click away
*then try to read it again in the pc.
Jun 22, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
The picture can't copy or move
try to put your memory stick in a different device that can read memory stick like psp, card reader, sony camera etc, then plug it into your coputer then try to copy the image.
May 10, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
How do I read a memory stick in my Dell latitude
hi, just put the memory stick into your card/stick reader port on your laptop then wait a minute or two and if nothing appears on the screen just go into my computer and then you should see the stick listed under my computer, if not then you need to check if your laptop can read that sort of stick.
The kind of memory computers have problem with is like nokia memory cards but all memory sticks should work, if its a usb type stick then this will show up under my computer, it should load up on its own but if not look under my computer.
Let me know how you get on or if you need further assistance ok
Jan 20, 2010 | Dell Latitude D600 Notebook
SanDisk memory stick pro duo 4GB not reading
does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
Oct 13, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
Sony memory stick pro duo is too small to fit in my computer media stick compartment. it won't read
its to small b/c when u bought the media stick it should have came with an adapter that you put the stick into and it makes it bigger inorder to fit into the computer.
Sep 17, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Will read memory stick
Memory Stick Pro Duo is NOT in the list of supported flash media for the RX500.
However I would expect the machine would be able to read the memory stick. Have you tried more than one Memory Stick Pro Duo? If not try another one and see of the problem persists. If it does, contact Epson and ask if the machine should read the format.
It is possible that the capacity and density is outside the range of the machine.
Oct 18, 2007 | Epson Stylus RX500 All-In-One InkJet...
Kodak EasyShare Z650 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
