I have just installed a Thermaltake TR2 RX PSU and the PC shuts down in roughly 2 minutes, regardless of boot media. HDD (windows shuts down) bootable cd rom. Other info is the PC was recently transported as luggage on an aircraft
    Problem Solver:
  • 17 Answers
Send the unit back and get another power supply. These units are known to not be able to keep up with the load. Here is something I found discussing them:
I already had mine replace by Thermaltake (that was nice of them) but here we go again... I have to send this replacement unit because (same as the first) it shuts down/reboots whitout any warning. it has lots of connectors, but what good are they if it can't keep up. the first unit also was overheating way too much, I have to say that the replacement does not overheat, its actually cool (when it works) but I can't recommend this unit... too many reboots, without any explanation of something wrong.
Please remember to rate my soultion...
Posted on May 07, 2008
Though it had been working fine until two days ago, my HP z800 won't boot past the "Starting Windows" animation; it simply turns off during its usual lengthy but verbose boot.
a HP z800 Desk top., full sized too.
what options? what does it have inside, now. ok 1 VGA card now. but is there a CD/DVD or BR disk drive there? options?
running SSD ! good.
its sold with a wide range for RAID drives, options.
and dual Quad-Core Intel Xeon Processor 5500 Series.
7 huge drive bays,
ever think to boot to a Linux CD? LIVE (no HDD need be there)
or windows 7,8,10 LIVE PE windows disk. (no HDD need be there)
my guess is if that fails (above simple test), then the PSU is bad.
it turns off for only these reasons.
1: the OS told it to.
2: the PSU saw errors and turned it self off.
the cause list is huge. (even bad MOBO, bad ram, or anything plugged into that MOBO that is shorted.
The PSU if it sees faults on any of its many power bus lines
it shuts off as after 1full second of trying to get it right (ATX spec)
why not just strip it down to only
mobo,PSU, no vga? , 1 mem stick.
see if fans run, powered on and it holds, there.
have as little plugged in to MOBO is possble
see if you get beep codes or , plug in 1 USB keyboard
and see if the LED there have flash codes.
ever seen a live boot CD? or stick
today all techs, have a boot stick, i have 4,
that why we can test everything out, with no HDD present.
see the POWER OF THAT?
I take a LIVE PE or linux, ISO file and burn a USB stick with RuFUS.
then boot to it, keep it in the tool box. and be empowered.
The PSU when working, some dont shuts off for 2 reasons
Power bus overloads, over/under voltage tests, or the soft power off
bit is TRIPPED.
if no HDD present there will no soft power off , possible. dig?
you push the power button and the PSU must stay up
do the fans go off too, ? you never mentioned FANS.
mine has 4 fans,
if the fans good off, now HDD then the PSU is bad or just UNHAPPY.
unhappy means, OVELOADED.
The more fancy the PSU, the more possible ways to overload
they do that to keep from blowing to kingdom come, $500 set of
processors. (a good thing)?
one more hint, the PSU has this one wire.
called PWR-OK if the PWR-oK goes false, the PSU
shuts off.
learn how this works and all else is easy.
Jun 18, 2017 | HP Computers & Internet
Thermaltake TR2 600W
It may work, but that will depend on the connectors you need and the ones on the PSU. Dell make some really weird cases and have some custom made PSU's If it will fit and has the connectors you need, then try it. The Thermaltake PSU is a standard ATX supply so it should fit.
Sep 01, 2013 | Dell Inspiron 530 Desktop Computer
Restarts unexpectedly
It can be one of three culprits with this unit -- first, try running it without the front panel plugged into the motherboard (the one with the front USB ports) and set the BIOS to auto power-on. If it keeps running after about 2-3 hours, then it's a bad cable. If not, swap out the PSU. A Thermaltake TR2 430W from Frys or MicroCenter works perfectly. If that doesn't stop it, take a good hard look at the capacitors near your memory on the motherboard. If they are even slightly 'popped,' then the board / memory controller may very well be bad. Swap the motherboard.
May 04, 2012 | Dell Dimension E510 PC Desktop
Guys if someone can help me i have 3 pc's with Dx58 So motherboards after a while of working a blue screen pop up and the pc restart.... PC specs: Intel DX58SO 3.20 GHz - i7-960 8M/LGA1366 ...
The Blue Screen could be a Hardware error but sometimes it is software (such as Drivers). Did you just replace the motherboard with a different one? If you did then that the problem, Windows does not like it when you switch Major hardware on it. If you want to troubleshoot further, only connect the essentials on to the computer and disconnect any fire wire or USB devices you have connected.
The BSOD or Blue Screen Of Death can both be hardware or software, Usually if you installed something on the computer such as a driver then it is most likely software and you should be able to log in by going in to safe mode (press F8 Repeatedly as the computer is booting up)
If its hardware, Then it can most likely be your Hard Drive or you Memory and would need to run a scan to figure out which one went bad
Hope this helps!
May 04, 2011 | Intel DX58SO Motherboard
Odd PC Build Bootup Problem:: I recently built a PC and have an odd problem when booting up. Build: MOBO: M2N32-SLI Deluxe CPU: AMD 6000+ RAM: Corsair 2 x 2048 PC6400C5 GPU: Sapphire Radeon HD 4670 1GB...
Instead of connecting you're fans to a single 4-pin molex on the power supply why not use the motherboards 3-pin molex fan connectors coming off the motherboard. See page 2.2.4 in your manual. Though I agree you should still be able to run 4-pin molex connectors to all fans off of you're PS. Allow the mother board to supply the 12v current to you're extra fans.
CHA_FAN1
CHA_FAN2
CHA_FAN3
CHA_FAN4
You're motherboard will supply the needed power. Less wiring will also allow better air flow through out the system and less strain to the fan controllers.
4-pin molex to 3-pin female; http://www.avadirect.com/product_details_parts.asp?PRID=11410
OR
http://www.microbarn.com/details.aspx?rid=101317&source=froogle
Happy New Year!
Mike
Dec 29, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Thermaltake Power Express 450 problem: Have to wait one hour !
The problem is obviously with the Thermaltake PSU.
I'm thinking either it's not turning on at the same time as the primary PSU, or it isn't feeding stable, clean voltages to the graphics card. Either calls for a return to the manufacturer.
Now on to getting your video working. What you want is enough power going to your video card. Try connecting the card to your primary PSU instead of the Thermaltake one. 630W might be enough depending on how reliable the brand is, as they often lie.
If it doesn't work, getting a more powerful primary power supply will fix the problem. Go for 750W+to be safe.
Apr 11, 2009 | Thermaltake Computers & Internet
PC Not booting up
HI
Please change the smps your cpu and check it..
i'm sure it will work..
Nov 19, 2008 | Computers & Internet
System failure
do any lights come on ... on the motherboard itself... some have lights some don't.
i would suggest it is a hardware failure.... if you have onboard video remove the video card and attempt to boot.... .. unhooking devices will help you to narrow down what the issue is...
also shut off the power and unplug it.... feel the capictors on the motherboard with your fingers... do any feel rounded at the top ?
Robert
Sep 07, 2008 | MSI Computers & Internet
Dell 5100 Dimension - No Power
there are fuses inside psu`s some are solderd and some pop out it i would suggest that u throw the psu away and buy new chances are that it will only cause continues and may even result in
complete mobo failure problems heres a link to a cheap psu   http://www.microdirect.co.uk/(3649)400W-P4AMD-quiet-PSU-with-PFC-20-pin-24-pin.aspx or a more upmarket more powerfull http://www.microdirect.co.uk/(11879)ThermalTake-TR2-500W-Black-Silent-ATX-12V.aspx the choice is yours.
Nov 18, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Open Questions:
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
