Question about Sport & Outdoor - Others
Northwest territory tent manual for item # 81-19-01 or printable setup instructions for that model.
Owners manual for Northwest territory 15x15x86in tent model 03-88-44 Blue Ridge
Try Googling (northwest territory)(03-88-44)(manual) without parens or contact Northwest Territory directly.
Jul 01, 2017 | Sport & Outdoor - Others
Northwest territories 7x10 cabin setup instructions
notify northwest territory or location bought and request instruction sheet
Aug 11, 2016 | Cars & Trucks
Where can I order replacement poles and pieces for my northwest territory front porch tent
check with the place you got your tent.perhaps they know who makes it ,
Feb 19, 2016 | Sport & Outdoor - Others
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
Manual for a northwest territory portland dome tent 17' X 9'
I NEED POLES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT SAYS IT SLEEPS 8 PEOPLE AND HEIGHT IS 70" IT SAYS NEXT TO THE UPC BAR CODE IT WAS MADE FOR KMART.
I CALLED KMART THEY SAID SEARS.COM HAS SOME REPLACEMENT KITS THAT WOULD WORK THERE IS LIKE 8 DIFFERENT KITS. COULD SOME ONE TELL ME WHAT KIT WILL WORK WITH THIS TENT. THANK YOU INADVANCE.TIM
Jun 01, 2012 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
394 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
