Question about Sharp UX B700 Plain Paper Inkjet Fax
Problem in machine
Machine gives error check paper and printer error.
  • 1 more comment
  • jta78 May 27, 2008
    printer error and line error comes up on the machine
  • joycebgood Jun 04, 2008
    I changed the cartridge but keep getting the same response printer error and check paper. I've tried at least 15 times, putting in, pushing down on corners of machine. Nothing works.
  • Miemie Jun 13, 2008
    I had printer error and check paper error. I just kept re-adjusting the paper til that error was gone. Now I have replaced the ink cartridge, but the printer error is still there.
I keep getting a printer error.
I have checked paper for jams, none.
Any solutions?
Posted on Jul 15, 2008
    Problem Solver:
Fax jamb
Posted on May 21, 2008
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
Feb 02, 2015 | Samsung SCX-4725FN All-In-One Laser...
Paper tray empty error message
no worries...it could be your drivers are shot..turn off machine, and let it sit for 10 minutes..unplug from computer, turn on, then tray a test page from front panel
Apr 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jam error but no paper
If you previously had a paper jam and you are getting this error, make sure there are no small pieces of paper left behind. The printer will detect this and give this error. If the machine is clean, try unplugging it from your outlet and then plug it back in. It should clear the error.
I hope this information helps you,
Thank you,
Nico
Jul 08, 2011 | Epson Stylus CX9400 Photo Printer
Correct loading of ink cartridges. Error E2
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
Dec 08, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Fax alarm is flashing and says check printer, fax in memory.I unplugged and rebooted.Any help is apreciated.
Please give me the error it shows on the screen when it says check printer!Check printer is a serious error!Thanks
Mar 26, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
My hp printer is telling me that i need to add
Not sure what printer you have but most consumer models don't actually detect paper in the tray. These machines will give an out of paper error if the paper is not picked up from the tray.
If the machine sounds like it is trying to pick up the paper but giving the error check and clean the pick up roller and look for something blocking the paper path.
hope this helps
Mar 15, 2009 | HP Office Equipment & Supplies
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
"printer error - check paper" after cartridge replacement
First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
150 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
