Question about Whirlpool LER7646E Dryer
Drys too slow - Whirlpool LER7646E Dryer
  • callcnetone Aug 28, 2010
    regarding my dryer not drying that I just posted...after posting it, I was reading suggestions regarding other similar postings and...many mentioned that I needed to test if it was a venting /hose clog problem. As they instructed, I simply took the hose off and let it dry without a hose for about 30 minutes and immediately noticed that it was drying clothes in 30 minutes instead of 2-3 hours it had taken before. After inspecting where the hose connects into the wall I determined that there was a kink that was cutting off most of the air supply...thats all that has been wrong for two long months! Yup you guys just saved me a $100 service call...thanks! ps my wife is also very happy...yeah!
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 28, 2010
Wont crank when damp then ok
Did you happen to leave the windows down during the serious mist? If so, Nothing inside the car has weather pack seals on the plugs. So it could be practically any thing on the inside. I would look at the ignition plugs, fuse/relay panel plugs, and BCM plugs. Look for corrosion. White to a greenish color.
Apr 26, 2015 | 2001 Audi A6 2.7T
How do I clean the lint trap. Drys slow
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Apr 02, 2011 | Dryers
2004 suzuki 2.5 cleaned the throttle body with wd 40 & a rag with some thinner on it ,now the engine idles faster & transmission shifts hard when slowing down.any ideas
Throttle position sensor. Pull the plug and clean it with brake clean. Never use thinner on your car it eats rubber. Brake clean cleans oil and carbon and doesn't leave a residue. And it doesn't eat the seals out of sensors. It drys to quick.
Feb 14, 2011 | 2004 Suzuki Verona
Drys the cloth but slow drying!
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 07, 2010 | Whirlpool Dryers
I have an 80s dryer that thumps and slows down somewhat, but otherwise drys.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Maytag Dryers
My watch keeps slowing down
If your watch is an automatic watch and not a quartz(battery)then it needs to be worn 6-8 hours a day to maintain power in the main spring as its motion that winds the watch.
If you are wearing the watch and its slow then it may need a service if its 3 years old or more.All the lubrication drys out and the watch needs cleaning,re lubricating and testing.
For this work you will need a skilled watchmaker go to www.rolexrepairs.co.uk where a postal repair service is available.
Aug 17, 2010 | Cartier 21 Chronoscaph W10125U2 Wrist...
My new electrolux gas dryer doesnt get hot enough so it drys too slow.
contact the store you bought it from for service
Apr 09, 2010 | Dryers
Dryer will not dry on auto setting, drys slow , over an hour on high setting
This sounds like your venting is eather too long or has a kink in it or is full of lent. First check behind the dryer for a crushed hose. Then check where the vent exausts. (The vent cap can also freeze up in the winter) If you are using plastic pipe (not recomended) change it too a rigit metal pipe. You should only have two elbos in your run. The shouter the pipe the better your auto dry will work.
Dec 22, 2009 | Dryers
Dryer intermitantly drys.
I have replaced several blower motors on these units for that problem. If the board doesn't read the blower motor speed it won't turn the heater on.
May 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
