Question about Whirlpool Duet GHW9150P Front Load Washer
The front door latch will not disengage from the hitch
  • 3 Answers
What I do to disengage is to unplug for a few minutes and plug it back in.
Posted on Aug 28, 2010
How to manually raise a 2009 sebring convertible convertibble top
When a trunk won't latch (or a door for that matter) it is usually because the latch isn't completely flip to the open position. On a door you pull the handle to operate the latch or on a trunk you either put the key in and turn it to unlock it or press the unlock button is electrically operated. Now the trunk or door should close and latch.
Aug 09, 2014 | 2009 Chrysler Sebring - Convertible -...
How do i take off the inside drivers door panel on a 2005 dodge caravan
Hi Roberta, here's the instructions on how to remove your door panel. I have to wonder though on why you are removing it, my guess is you window doesn't roll up or down and your replacing the regulator. Any way here goes.
REMOVAL
  1. Remove the plug and remove screw attaching door pull cup to inner door panel.
  2. Remove switch bezel and disconnect power window/memory switch.
  3. Remove screws attaching trim panel to door from below map pocket.
  4. If equipped, remove window crank. (Refer to 23 - BODY/DOOR - FRONT/WINDOW CRANK - REMOVAL)
  5. Remove screw holding door trim to door panel from behind inside latch release handle .
  6. Disengage clips attaching door trim to door frame around perimeter of panel.
  7. Lift trim panel upward to disengage flange from inner belt molding at top of door.
  8. Tilt top of trim panel away from door to gain access to latch linkage.
  9. Disengage clip attaching linkage rod to inside latch release handle (INSIDE DOOR HANDLE LINKAGE).
  10. Separate linkage rod from latch handle.
  11. Disconnect the power door switch, courtesy lamp electrical connectors.
  12. Remove front door trim panel from vehicle.
Hope this helps and have an awesome day Roberta!
May 21, 2014 | 2005 Dodge Grand Caravan
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
Remove door panel
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors.
    Fig. Expedition - Trim Panel Screws shown
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
    Fig. Navigator - Trim Panel Screws shown
  10. Position the water shield aside.
  11. If equipped, disconnect the lock cylinder rod.
  12. Disconnect the exterior door handle actuating rod.
  13. Remove the bolts and position the front door latch aside.
  14. Disconnect the electrical connectors.
  15. Release the interior door handle cable and remove the front door latch.
  16. Position the cable cover aside.
  17. Release the conduit and the interior door handle cable.
  18. Release the locking tab and remove the front door lock actuator.
  19. To install, reverse the removal procedure and note the following:
    1. Tighten the door latch screws to 80 inch. lbs. (9 Nm).
This procedure is followed to check and fix door locks.
Hope helps.
Jan 12, 2011 | 2001 Ford Expedition
How do i remove the driver's inside panel door? My electric button panel for windows and locks isn't moving.
Like reference guide, check this procedure to Removal & Installation / Door Lock Motor...
The door lock motor is integral with the door latch. If the door lock motor is found to be defective, the entire door latch must be replaced.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Roll the door glass down.
  3. Disengage the 2 clips attaching the speaker grille to the door trim panel. (They are at the front of the grille, one near the top, and the other one at the bottom).
  4. Remove the 3 large washer-headed screws surrounding the speaker.
    Fig. Fastener location for the door lower trim panel
  5. Remove the access cover at the front of the door trim panel. Remove by prying at its rear edge.
  6. Remove the red courtesy reflector from the lower tail of door. Disengage by prying at the screwdriver notch at the bottom of the reflector.
  7. Remove the flag trim panel from the door by prying it off at the 2 attachment clip points.
  8. Remove the 7 screws attaching the door trim panel to door:
    1. One screw is located at the lower rear screw pocket.
    2. Three screws are located along the bottom of the door.
    3. One screw is located inside the handle opening.
    4. One screw is located at the upper front.
    5. One screw is in the pull cup.
  9. Disengage the 2 hidden clips attaching the rear of the trim panel; pry them off at the 2 attachment clip points.
  10. Lift the trim panel upward and away from the door, disengage the trim panel from the upper retainer channel.
  11. Disengage the clip attaching the latch linkage to back door handle.
  12. Disconnect the electrical connectors as necessary, including the lower foot light, if equipped.
  13. Remove the door trim panel from the door.
  14. Remove the water shield (water dam) from the inside of the door.
    Fig. Remove the flag trim panel, door trim access cover, inside remote handle, and power door lock switch
  15. Raise the door glass.
  16. Remove the bolt and nut for the rear glass run channel and position the channel aside.
  17. Disconnect the lock rod from the lock button bellcrank.
  18. Disengage the lock and latch rods from the clips on the inner door panel.
  19. Disconnect the lock and latch rods from the outside door handle and the key cylinder at the door latch.
  20. Disconnect the wire connector from the power door lock motor.
  21. Remove the screws attaching the door latch to the door end frame.
  22. Remove the door latch and the power door lock motor from the vehicle.
    Fig. Expanded view of the door lock, latch, and linkage
    Fig. View of the door lock button, latch rod, lock rod, and door latch
Hope helps (remember rated this).
Jun 26, 2010 | 2000 Chrysler Sebring
Front passenger side door will not close because closure latch is engaged. how do I disengage closure latch to close door?
Just use a screwdriver to fit into the area where the latch part lock onto the bar, pull the handle you use to open it while prying/pulling the screwdriver & the jaws will open again to allow it to close.
good luck.
Feb 13, 2010 | 1999 GMC Suburban
Can't get the door to unlock? Load in washer is beeping ND..not draining but after several attempts inlcuding shutting power off..still can't get the door to disengage?
In front loader machines there is a safety latch that stops you from opening the door if there is water in the machine. I think it needs power to release the latch, I am not familiar with this model.
You probaly need to drain the water off somehow.
Dec 16, 2009 | Maytag MAH2400A Front Load Washer
How to remove rear door panels on a 2003 ford f 250to get to door switch
Tailgate latch, handle and lock
  • Open the tailgate.
  • Remove the two bolts and detach the door stop.
  • Lower the tailgate and remove the tailgate access cover.
  • Disconnect the control rods.
  • Detach the retaining nuts and remove the handle and lock cylinder assembly from the tailgate.
Door trim panels
  • Disconnect the cable(s) from the negative battery terminal(s).
  • On manual window equipped models, pull the window crank cover aside, remove the screw and detach the handle.
  • On the front door of power window equipped models Pry up on the retaining clip at the front edge of the armrest and lift the armrest switch control plate out and disconnect the electrical connections,then remove the retaining bolt from the opening.
  • Use a small screwdriver to pry off the courtesy light cover for access to the trim panel retaining bolt.
  • Carefully pry off the mirror trim panel from above the front edge of the door panel.
  • Once all of the bolts are removed, remove the trim panel by gently pullingit up and out .Detach the courtesy light bulb housing from the panel.
  • For access to the inner door components, remove the speaker (if it would interfere with watershield removal) and the screws from the trim piece at the lower trailing corner of the door, then carefully peel the watershield from the door.
  • Remove the screws securing the latch.
  • Working through the large access hole, position the latch as necessary to disconnect the electrical connector and disengage the outside door handle and outside lock cylinder to latch rods and the inside handle-to-Iatch cable.
  • Detach the locking rods by unsnapping The remaining outside handle retaining nut can be reached through the access hole in the door frame and the upper striker the portionof the plastic clip engaging the connecting rod, then pulling the rod out of its locating hole.
  • Position the latch as necessary to disengage the door lock actuator hook. Detach the cable cover and disconnect the cable from the latch. Remove the latch assembly from the door.
Oct 30, 2009 | 2003 Ford F250 Super Duty Crew Cab
Door latch
DE error code is because there is a drain problem and it will not lock the door.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
