Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
I am not sure of the range model number, but the problem is that the electronic igniter continues to click when the stove is off. It is an intermediate problem - comes and goes. the "spark module" is an Invensys U-67340-95; also has these numbers on it: 7431PO51-60; DAR 03-012 and DAR 03-007. do i just need to replace the module?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Aug 28, 2010
Is it normal to have a smell of gas in the initial start-up process using the stove top?
if you have electronic igniters you may get a wiff of gas at start up.
make sure your igniters are set properly so the burner lites right away and does not click click click for awhile before starting.
Jun 21, 2015 | Stoves 600SiDOm Gas Kitchen Range
How do i turn the pilot light off. I want to use a bug fogger in my apartment and i want to temporarily turn off the pilot on my stove
This model should have pilotless electronic ignition.If you hear clicking when you light the burners , it is electronic,. Also , open broiler drawer and turn on oven .After a few seconds do you see a glow start?Thats your electronic oven igniter confirming you have no pilot.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Electronic ignitors click continuously
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 22, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Vulcan 60LC
See page 19 of this form
http://www.vulcanhart.com/manuals/F30536.pdf
Ignition module part # 857207-1
Your local Hobart branch may carry that in stock
http://www.hobartservice.com/Locations/
Hope this helps
Jun 14, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
178 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
