Question about Magic Chef 31000 Gas Kitchen Range
How do i re ignite the pilot light - Magic Chef 31000 Gas Kitchen Range
  • 4,323 Answers
Hi
The surface on this range have standing pilots that must be lit initially. To light them:
1. Be sure the surface burner control knobs are in the "OFF" position.
2. Remove the grates and cook top.
3. Locate the pilot ports and light each of them with a match. Replace the cook top and grates.
Light the oven burner pilot in the following manner:
1. Be sure the oven control knob is in the "OFF" position.
2. Remove the broiler carriage.
3. Hold a lighted match at the top forward section of the pilot (See diagram). No adjustment is required.
4. Replace the broiler carriage.
Hope this helps...
Daniel
Posted on Aug 28, 2010
How can I reignite the pilot?
The nozzle for the pilot light may just need cleaning - use your vacuum cleaner to suck any dirt out.
There usually is an igniter button to restart the pilot light. Press it in and wait a few seconds, then press it again. The pilot light should re-ignite
Mar 13, 2016 | Heating & Cooling
How do I relight the pilot light
There are many different ignitions for pilot light burners. Some are piezo ( You have to press a button to ignite the pilot) , battery ignition, there will be a switch somewhere on the oven to press or switch , or full auto ignition, which is done by an electric ignition pack usually situated under the oven or mounted on the rear at the back. The full auto ignition will light the pilot when you turn the oven on. Make sure you have the gas on, battery is new (If battery ignition) or power is available.
Sep 30, 2015 | Kitchen Ranges
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
Pilotlight is not igniting. I have it in the on position but it is not on and hence not igniting the ga. I would like to know what I need to do to get the pilot light to light
From what I just read online your heater uses a hot surface igniter to light the pilot. Turn the heater off. Give it a couple minutes, maybe 10. Then turn it back on. It probably goes through a purge cycle first then tries to light the pilot. You should be able to see the hot surface igniter glowing red somewhere close to the pilot. If not the igniter may be bad. Let me know what you see.
May 08, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
Igniter sparks after several tries but the pilot will not light
no gas is getting to pilot light. if all else fails change thermal coupling, if this is bad no gas will come out.
Nov 05, 2009 | Water Heaters
Pilot light gone out
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Magic Chef 31000 Gas Kitchen Range Logo
337 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
