Question about Poulan "Poulan" Push Mower
A friend has a poulan push mower and hit a pretty big rock with it, and now when you pull the pull cord to start it, it pulls hard and will not start. It is not the flywheel key sheered off, that is fine, so I am wondering if there is something else it could be or if the drive shaft got bent and it needs to be scrapped?
  • mepurpleturt Sep 02, 2010
    I took it all apart, checked everything over, replaced the blade, blade attachment kit w/shear key, checked the flywheel key, had to replace the safety cord and plug, now it idles great, but, so far, I have literally broken two of the blade attachment kids where it goes around the shaft, yet the shear key remains in tact.
    Now I am not sure if it is a bad batch of attachment kits or something more, especially since the blade spins freely, no apparent bends in the shaft at all and does not hit the sides anywhere.
    It sounds great when it runs without the blade on, so I hate to give up just yet.
  • 903 Answers
Hi, it sounds like it's most likely that drive shaft. If the drive shaft gets dirty or dry you'll get the same problem with the pull cord being hard to pull, so more than likely that shaft got bent somehow and now it won't pull.
If you turn the mower over, can you turn the blade by hand? Maybe you can see if the shaft is bent as you try to turn it.
Posted on Sep 02, 2010
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
The engine is not started
Hi.
Check the blade... it is bent and causes a vibration. if it is not the blade then the motor shaft is bent and that is terminal...if that happened then the mower is junk...
heatman101
Jul 12, 2010 | Poulan "Poulan" Push Mower
Trying to fix the pull cord on my Poulan push mower... Removed the top cover and don't know what tool to use to remove the cover for the cord - any ideas?
Many mowers use large bolts, which you can remove with the right-sized nut driver. Do you see any bolts sticking out of the cover? If you don't have a nut driver, a socket wrench or even adjustable pliers will work.
May 15, 2010 | Poulan "Poulan" Push Mower
Lawn mower engine stops while pushing
sounds like the float is set too low or you need to clean the carb.check the fuel filter and tank screen also.
Jul 29, 2009 | Poulan "" Push Mower
Broken pull cord. how do i get to the inside to fix it?
you need to take off the top cover. there are about 4 to 6 bolts to remove. the pull cord and winder will be under top cover
Jul 25, 2009 | Poulan Garden
Mower hit a big rock and stoped running
If you hit something hard enough to partially shear the key on the blade adapter, you did shear the key on the flywheel, and it will need to be replaced for the engine to run properly.
Apr 11, 2009 | Garden
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Poulan "Poulan" Push Mower Logo
244 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
