Where is the drain pump filter located on the samsung wf203ans
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Service (repair) manual for Samsung WF203ANS/XAC
You have this listed in the Projection TV area--try posting a new question in the major appliance area---if you post the model number a expert in that area MAY help you or suggest how to get what you want.
Posted on Apr 07, 2012
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Is there a filter on Samsung washer model WF337AAL/XAA
should b were the pump connects to or up inside the hose from mech to pump
Feb 19, 2015 | Samsung Washing Machines
Where is the drain filter located on the Samsung Silver VRT front load washer?
I have a similar model and there is a bottom panel which can be prized off with a flathead screwdriver or similar. Behind this panel you will find the filter.
It sounds as though you know what you are doing with these machines but hopefully you just missed this trick.
Andy
Nov 13, 2013 | Samsung WF337AA Front Load Washer
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
Apr 06, 2012 | Televison & Video
Where is the drain filter on a samsung front loader? I am getting a nd error when I removed the hose from the pump, water came gushing out of the pump. Before I removed the hose, I made sure that the...
Hello & Welcome to FixYa
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Samsung WF328AA Front Load Washer
Samsung vrt steam Brand new first load ran fine till drain cycle then received a "No Drain:check drain pump filter" All filters are new and clean. No kinks or leaks anywhere.
Contact the vendor!!! I assume it is still under some sort of guarantee/warantee? You can nulify any guarantee if you attempt to fix problem before contacting vendor.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 09, 2011 | Samsung WF337AA Front Load Washer
WF328 AAG OE error code...how do reset this? or can I reset this?
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 24, 2011 | Samsung WF328AA Front Load Washer
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
