Words disappear off edge of screen no matter which aspect I use. Panasonic TX28DTX11
  • 42 Answers
Make sure the video device is set properly formats and ratios. If that is not the problem then there is an issue with the allignment and you should have it professionally adjusted. Sometimes with age service settings get out of proportion with the dimming of the bulbs.
Posted on May 12, 2008
How do I stop the words from being cutoff on the tv screen?
You need to check the zoom or aspect ratio on your TV remote and or your cable/satellite remote. The zoom or 16:1 aspect ratio often cuts off words if the movie or show is in 4:3 ratio.
Jan 04, 2015 | Panasonic Viera TC-P50S1
The picture on my screen is to big to fit on the screen, no matter what aspect ratio it is set on.
where is the picture coming from? Is it a media player or dvd player? If so, does that need to be set for the specific output
Mar 07, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Can't see words displayed at bottom of screen
Check your menu for horozontal and vertical size adjustment to see if you can reduce the size of the image. Or try to change the aspect ratio. Last resort is to do a system reset.
Jan 16, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. On certain channels the screen is too big and I can't see the edges of the broadcatsed...
This is a quote of what Sanyo told me: "The aspect ratio can only be changed when the unit is in the video mode." So I tried switching modes with the input button and it worked but went to like a letter box/wide screen type of picture, which doesn't help me. We have dishnetwork and on the Panasonic plasma we can adjust the ratio with their remote so I have two options there but not with my Sanyo unfortunately. Hope this helps
Jul 22, 2009 | Sanyo DS24425 24" TV
Edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Jun 30, 2009 | LG 37LG30 37 in. LCD HDTV
Picture not to edge of screen
That is because you are watching the picture in the 4:3 aspect ratio. This is normal when you are watching a channel that is being broadcast in 480 or digital. But once you tune to a station that has 1080 or at least 720p which is true high def then the picture should expand to 16:9 aspect ratio. It will switch between the two automatically as it determines what type of signal it sees. You can force the resolution to change by pushing the format or aspect ratio button on the remote but you will lose picture quality.
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Almost fixed!
see my last post to you regarding the converegence resistors
Jun 15, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Projection off the screen?
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Feb 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
