Question about HP Color LaserJet 2600n Printer
Lj2600n no output
Networked printer on domain prints fine from local server it is installed on and can print from remote pc's on domain but cannot print from local pc's? print just sits in queue and does not seem to reach printer itself?
I need HP colour laserjet 2600n software supporting to windows vista
Posted on May 15, 2008
Im trying to print from another computer
If you wish to print via a print server, please be aware the printer should be installed as local printer on this PC and shared. After this you can install the printer on the remote pc using the option add printer > network printer and point to the other pc using UNC as \\ip adress of the pc where printers is installed locally\name of the printer.
Aug 27, 2010 | Brother HL 2140 Laser Printer
My Xp clients are on windows server 2003 domain. My clients are using HP LaserJet 1020 printer which is shared on network. My users complaints that when they print any documents, Printer does print fine...
http://support.microsoft.com/kb/314073 hope this will help you or else please give me remote session of your computer
Available at Skype:- amit.bhardwaj4
Mar 01, 2010 | HP LaserJet 1020 Printer
Can't print in SAP R3 to HP LJ2600n
Supported HP Printer: HP Color LaserJet 2600n printer
(Host-Based)
Recommended PCL5 Device Type: SAPWIN
- requires Server-based printing via SAPSprint or Frontend Printing via SAPgui
Supported SAP Release: See SAP Note # 8928
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Toshiba e studio166 shared printing problem
try adding printer and browsing network for printer, it should see the host and printer and add using correct network path, if you don't see host computer "print server" then you aren't on correct network path
Jun 24, 2009 | Toshiba e-STUDIO166 Printer
Printer is not geting my print commands
What driver are you using on your vista machine? It would be better to load a local printer on your laptop and create a standard TCP/IP port using the address everyone else is using and load the driver locally instead of network printer. Also if you are using a print server to make it networkable you probably need the GDI version of the print driver loaded not the PCL5 or 6. It can be downloaded from sharpusa.com. PCL driver only works if PCL Print option is installed on the device. This would also give you a nic port on the copier as well, so if you have print server you probably don't have that option. If you need more specific details let me know.
Hope this helps,
TankMurdock
Apr 24, 2009 | Sharp AR-M205 Copier
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Pixma ip 5200 r -> CD Labeler Problem
After long research .... I found out that the pixma is indeed a network printer ;) .... BUT it has a printserver already build in!!!! Having 2 Servers is obviously not too good of an idea ;) ....still wonders me as to why it did work in the 1st place ..... (i guess there was something wrong with the w2k3 print server *muhaahha)
May 07, 2008 | Canon PIXMA iP5200R InkJet Photo Printer
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
Printing to a Canon MX310 through a print server
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Nov 11, 2007 | Canon PIXMA MX310 All-In-One Printer
HP Color LaserJet 2600n Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
