Question about Sharp AF-M1909Y Air Conditioner
Water leaking on carpet. drain plugged? - Sharp AF-M1909Y Air Conditioner
  • 70 Answers
Make sure it is pitched right and yes the \drain could be blocked. There should be screws on the side and the hold unit will slide out of the caseing then clean it with a hose let dry for and hour or so should be good.
Posted on Aug 28, 2010
Xj6 water leak
If it is when your a/c is being used, the drain for the ac heater box is plugged up. If it is only when it rains, could be the drains for the sunroof.
Jun 24, 2012 | 1997 Jaguar XJ6
My 1986 lebaron convertable leaks and there is water in the car rocker panels and sloshing behind passenger seat. How where are the drains
the drains should be under the carpeting,if you lift up the carpeting and look around you should see them.the are either a metal plug or plastic plug and if you remove them the water will drain out the floor.you should also vacumn the carpets with a wet vac to get as much water out of them or they will smell and get moldy.
Apr 12, 2011 | 1986 Chrysler LeBaron
Water keeps leaking out onto our carpeting.
Check the drain lines to make sure the are not plugged and check the hidifier pad to be sure it is not scaled up and not letting the water flow through the pad. Last thing is make sure the humidifier is level so the water isn't leaking out the cover instead of the drain.
Feb 18, 2010 | Humidifiers
Leaking Kenmore A100E
Take the unit apart and clean out the bottom with a water hose,clearing all the debre out of the unit.
Aug 30, 2009 | Heating & Cooling
Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
Jul 27, 2009 | 2005 Toyota Corolla
Wet carpet under front Passenger seat
You have drain blockage in the condesor case itself. There is a small tube that will drain the condensor case, the big black plastic case that contains most of your a/c system inside the car. This case collects moisture and that must drain normally from the case drain to the outside of your car onto the ground.. If this drain is plugged, you will have leakage on to the floor. If the moisture is allowed to remain in the carpet, mildew will set in and then you will have to replace the carpet.
Bill
Nov 19, 2008 | 2001 Volvo V70
Interior Carpet Getting Wet
It sounds like a plugged drain line from the air conditioner. Most cars now run in the a/c mode whenever u turn on the climate control (even when heat is on). The passenger side front is where it would be wet, and the carpet and carpet pad act like a sponge and will soak up the water. Let me know how u make out.
Oct 25, 2008 | 2003 Honda Accord
Leak onto floor passenger side from neck of ac drain through firewall
it sounds like your heater core is busted. you will have to go under the dash to get to it and replace with a new one
Oct 11, 2008 | 1999 Jeep Grand Cherokee
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Sharp AF-M1909Y Air Conditioner Logo
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
