My printer Brother MFC-660CN Usb will not print anything from my PC or my laptop. But it responds to scanning and copying commands.. The ink is fine and I have been through the troubleshooting with no success. This is bizarre. Can you help?
    Brigadier General:
  • 6,966 Answers
Initially and sorry but I have to ask, have you tried deep cleaning? This is normally one of the tabs/buttons in the maintenance/utility portion of the printer properties. In some instances, you may need to do the cleaning several times. Worst case scenario is a defective/blocked printhead.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 07, 2008
  • 256 Answers
Try taking out your ink cartridges. and reinstall them. Also check to see if your ink is low. If the printer has a rea cover remove it and see if the wheels the the paper is feed by is jammed or loose.
Hi I have a brother MFC-660CN, all colours are working but black has stopped, we have tried cleaning but it has not helped. do you have a solution? thanks in advance Janet
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 06, 2011 | Brother DCP 115C All-In-One InkJet Printer
Does printer need to be connected to a pc?
From the Brother website: The MFC-5440cn offers both a versatile flatbed and an automatic document feeder with faxing and copying that don’t require the use of a computer. Add to that the spectacular high-resolution printing and scanning with both a USB 2.0 full speed and an Ethernet interface and you have the perfect all-in-one for the Small Office/Home Office user to create and print professional color documents. You can even print borderless photos.
Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Brother MFC-5440CN All-In-One InkJet...
message says"removescanner cover,then reinstall cartridge," just renewed cartridge.
Jun 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Generic Problem or Brother specific? Help!!???
Thank you to coolguy88 who solved my problem by pointing out the obvious: reinstalling the drives for the printer, which I didn't know where seperate from the other parts of the all-in-one. Many thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 07, 2008 | Office Equipment & Supplies
you need always enough ink to keep this type of machine alive (printing fax, copy, scan). you have to replace the empty cart.
Feb 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
My printer won't print.
1:check the usb cable or replace it
2: remove the black print cartridge clean the contacts then reinstall it
Nov 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
Switch the machine on. Press the "Ink Management" key to the left of the screen. Go down to "Cleaning" and press ok. Chose the colour you would like to clean and press ok. The cleaning process uses a tiny amount of ink. Hope this solves your problem Good luck.
Jun 24, 2007 | Brother MFC 420CN All-In-One InkJet...
