Question about Sylvania SRT2232S 32" TV
32" sylvania TV thin line
Thin line appears when TV is turned on from cold start, sound is fine. Full picture appears after 20 minutes.
  • kbingram May 09, 2008
    Prior to attempting to resolder I tapped on the side of TV, then the sound was lost and the screen went completely black, but I could hear the high voltage portion still working.I found the IC, (the only IC on the board 12 pins) with the heat sink and resoldered all pins, no help, now when the TV is powered on the thin line appears for a split second, then sounds like the TV powers itself back off, should I replace this IC?
  • 4,234 Answers
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Posted on May 07, 2008
  • ABRsvcs May 09, 2008
    Most likely the IC has failed. Try replacing that first. It is possible that the supply voltage is not present. since that is derived from the flyback transformer, it is possible that this transformer is defective. Should that be the case, the cost will rise significantly. I'd first try replacing the vertical IC.
    Keep me posted.
Have thin line of picture on right side of screen, rest is blank. Sound is fine
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | LG 32LG30 32 in. LCD HDTV
White fuzzy thin vertical lines appear on screen. The picture is fine, but the lines are in front of it. Is this something than can be repaired?
Hello can you post a picture of your tv set with the fuzzy white lines thank you so I can give you the best sound advice.
Aug 19, 2014 | Sylvania Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Sylvania SRT2232S 32" was working
The problem is in the vertical deflection circuits which is responsible for giving a full picture. Since the set is 8 years old the money would be better spent on a new tv since more frequent break downs in other parts of the set would be more likely due to age.
Sep 15, 2011 | Sylvania SRT2232S 32" TV
Thin horizontal line with a Toshiba CF3062A
This is a problem with the vertical circuit that is usually a defective vertical IC. This part costs $10-$20 and is easily replaced. Sometimes there are capacitors in the same circuit that need to be replaced as well. Dan
Jun 09, 2009 | Toshiba Televison & Video
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair not turn it on until then,please.
Apr 17, 2008 | Toshiba 36A40 36" TV
No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | Toshiba 32A50 32" TV
Solder bad connects in vertical circuit,especially vertical output
IC pins.................T.
Dec 26, 2007 | Toshiba 35A44 35" TV
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Sylvania SRT2232S 32" TV Logo
424 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
