Cant wash it only spins hotpoint wt640 g - Washing Machines
  • Anonymous Jul 17, 2008
    washer wont agitate but it'll spin and rinse
  • 110 Answers
It seems as though the coupler under the agitator is stripped
Posted on May 09, 2008
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
Apr 01, 2017 | Washing Machines
Hotpoint washer wt640 front filter cover stuck
We had to use brute force, pliers and lots of wiggling back and fore. When we eventually got it out, about a pounds worth of small change and lots of gunk blocking the way.
Spin now working, f05 gone. Very happy as hotpoint wanted 95 pounds for a call out.
Good luck all.
Jul 29, 2012 | Hotpoint Washing Machines
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint wt640 has an error code F-05, what does this mea and what should i do??
My Hotpoint wt640 has an error code F-05, what does this mean and what should i do??
Feb 21, 2011 | Hotpoint Washing Machines
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
Hotpoint ultime wt640 has a slight squeek seem to be on front around door area had top off and turned drum motor and drum seem fine and springs ok
Remove rear cover of washer, remove drum belt,and from front of washer, spin drum by hand.
There should be no noticeable noise.
If you can still hear sqeek, then it could be a drum bearing that is dry or starting to fail. or the drum is rubbing on the front of the door seal
You should be able to detect what it is this way.
Please rate my solution.
Thankyou.
Jan 17, 2010 | Hotpoint Aquarius WD640 Front Load...
On the final spin the washing machine is so loud you cant even be in the same room as it, it is not vibrating externally as far as i can tell
Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Thanks.
Nov 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
