Question about LG LWHD1009R Air Conditioner
Where is the weep hole on LG LWHD1009R - LG LWHD1009R Air Conditioner
  • 70 Answers
There are i the back corner of the caseing
Posted on Aug 28, 2010
Ford engine diagrams
You did not specify which ENGINE your F-150 has, but I'll assume it's the 5.0L V8 (most common). The 5.0L only has ONE "weep hole," and that's at the base of the water pump housing where it mounts to the front of the engine block. There is no other "weep hole."
Sep 06, 2014 | 1988 Ford F 150
Weep hole
THE WEEP HOLE IS THERE TO TELL YOU THE BEARING AND OR SEAL IS GOING BAD.NOT A GOOD IDEA TO PLUG IT.
Jan 03, 2014 | Cooling System for Kia Rio
Lg lwhd1009r
Most window air conditioners run the fan all the time but cycle on and off the compressor that makes it blow cold air, I knew a AC that was a small Hunter Bay brand (which I think is LG) that shut fan off also when it reached the right temperature.
Hard to test them in winter, you may not have it warm enough in the room for it to start making cold air, generally speaking that could be the problem.
Jan 10, 2012 | LG LWHD1009R Air Conditioner
We have a LG model lwhd1009r. We cleaned out the unit and the coils are still freezing up and not cooling. We turn the the fan on and it thaws right away, but as soon as you turn on the compressor it...
there are 2 possiblities on this . 1 the indoor fan is running to slow you need to run it at hihg . or the unit is low on charge. Try running it on high fan and see if that does not solve the problem also close any vnets on the unit that say fresh air or outside air. when its really humide you don't need to bring in more. Let me know hope this help ... Jon
Aug 07, 2011 | LG LWHD1009R Air Conditioner
Haw long is the cycle time of the compressor on a lg LWHD1009R
Kevin, that would vary depending on the ambient air temperature in the room, the humidity level and what setting you have the temperature set on. There's no pat answer for your question.
Hope this helped you.
May 16, 2011 | LG LWHD1009R Air Conditioner
On my LG window AC Md. LWHD1009R, I cannot find a drain hole to let the water out. The back bottom of the pan was filled water containing a rusty sludge, but the heat exchanger coils are aluminum, so it...
usually in the middle underside of the window units is a hole that water drains out of, you can always drill new holes in order to make it drain, Good Luck Tim
Apr 24, 2011 | Heating & Cooling
Leaking fluid from what looks like a weep hole in from of abs.Is it a weep hole or something else
ABS units do not have weep holes. It might be a bleeder valve, but it's not supposed to leak. Have it looked at.
Jan 11, 2011 | Honda Prelude Cars & Trucks
I do not get any cold air from my lwhd1009r just bought it about 40 mins ago
You may have bought a lemon. Return it for a full refund or swap for another.
Jul 16, 2010 | LG LWHD1009R Air Conditioner
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
LG LWHD1009R Air Conditioner Logo
189 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
