Question about Westinghouse L1975NW Monitor
L1975NW monitor will power on but no image will come up. computer works with older monitor.
  • 4,281 Answers
When you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "enable vga mode" then go to display property in control panel.Then change screen resolution to 1024*768 then apply you can also change the display from there. You can change desktop background and other display settings from start menu->control panel->display.. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 28, 2010
Image blinks off after about 1 second after being powered up. Cut the power off at monitor, then turn back on and it repeats. Full image from computer shows up for about 1 second then disappears. The...
Please look here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 13, 2010 | Westinghouse L1975NW Monitor
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: http://www.ccl-la.com/blog/index.php/westinghouse-l1975nw-repair/ The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
Goes dark for 5 to 10 second for no apparent reason?
Look for bad caps in the power supply, it will get worst and can take out the inverter fuse and the MOSFET.
Feb 10, 2010 | Westinghouse L1975NW Monitor
Sound for Westinghouse L1975NW Monitor does not work. The computer doesn't recognize the built-in speakers.
Hello, I wuld love to help you out a bit more but I need some more information so we can troubleshoot. You can contact me at westytech@wde.com so I can further assit you.
Jan 27, 2010 | Westinghouse L1975NW Monitor
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
Jan 07, 2010 | Computers & Internet
Monitor is blank but green lightis on L1975NW
LCD Display/ control board Defective, send to repair
Dec 28, 2009 | Westinghouse L1975NW Monitor
Westinghouse L1975NW monitor: all of a sudden it display the bar that switches between "Text Mode" "Picture Mode" and "Economy" continiously. There is Exit button on that bar but my cursor cannot get...
One of the button across the bottom of the monitor is stuck. You need to just move the buttons on the bottom around a bit and then power it back on. Your problem should be corrected.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 10, 2009 | Westinghouse L1975NW Monitor
Westinghouse L1975NW Monitor Logo
91 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
