Question about Krups 203-70 White Fast Touch Grinder
How do I open the Krups 203 coffee grinder---we were away for 3 months and the resin from the coffee caused the blade to stick. Blades do not turn when we use power
SOURCE: Krups 203-42 Electric Blades coffee grinder
i HAVE THE SAME QUESTION.
Posted on Feb 07, 2008
SOURCE: flashing 8888 will not make coffee
I had a similar problem. It stopped working mid-brew, then flashed 8888 incessantly and I couldn't get anything to respond. I unplugged, turned it upside down overnight to drain. Next day it worked fine and has been OK since.
Posted on Aug 29, 2009
  • 279 Answers
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
Posted on Sep 18, 2009
  • 22 Answers
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Oct 19, 2009
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
Posted on Jan 31, 2010
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
How do you change the blade? I bought a new one but can't get the old one off. Thanks
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
How to remove blade 0f krupps 203 coffee grinder and clean the motor
On the bottom of the Grinder, You will find several Rectangular holes. With a flat screwdriver push tangs to release bottom. In main shaft, there is a small slot for a flat screw driver. Inseret proper dcrewdriver in slot and turn blades counter clockwise. This should remove blades..
Jan 25, 2011 | Krups Burr Coffee Grinder
When i turn it on motor doesn't turn just hear the hum like it is trying to turn but can't
It probably cooked the motor. You need to assess the cost of repair against a new unit and if your coffee will have a smokey taste if repaired also It would be easier to just buy a new one. Not worth the time or effort to repair.thanks
Jan 16, 2011 | Krups 203-42 Electric Blades Grinder
Hi, i have the krups 203 coffee grinder mill. i have misplaced the lid. where can i buy a new one? thanks
Here is the link
http://www.krupsonlinestore.com/product_list.asp?MENU=parts&SELECT=grinders&SKW=acccoffgrind
Jan 13, 2011 | Krups 203-42 Electric Blades Grinder
MOTOR HUMS. BUT BLADE NOT SPINNING.
See if you can turn the blades or reach a knife balde in to turn the blades....if something has jammed them.... get it removed... if they spin feely, then the motor is bad and replacement will probably cost more then a new one...
heatman101
Nov 30, 2010 | Krups 203-42 Electric Blades Grinder
Removing the blade on the Krups 203-45 coffee grinder
There are four little opening on the bottom through which you can see the clips. To get to the clips insert a screwdriver on the side and push one the clips inwards. Simultaneously, pull the bottom out. Repeat for other three clips. The process is not easy, I broke two of the clips. However, bottom seemed to go back on ok.
Mar 25, 2009 | Krups 203-45 Grinder
In my above solution there is a segment that reads "of the back of the E" which should be "at the back of the "E"".
Jan 13, 2008 | Krups 203-42 Electric Blades Grinder
Krups 203-70 White Fast Touch Grinder Logo
395 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
