Compaq presario C304NR notebook PC . with error message
STOP: 0x00000050(0xc7380000,0x00000000,0x8081E5C0,0X00000000).
THIS PREVENTED THIS SYSTEM TO REACH DESKTOP .
HAVE TRIED TO USE THE RECOVERY CD BURN FROM THE SYSTEM ALL TO NO AVAIL . I USE F8 TO GO TO ADVANCED SETUP AND SELECT SAFE MODE ALL TO NO AVAIL.
KINDLY ME HELP WIT UR PROFESSIONAL ADVICE
LoadTOCNode(1, 'symptoms');-------------------------------------SYMPTOMS:------------------------------------
When you restart your computer after you install Windows XP Service
Pack 1 (SP1), your computer may generate the following Stop error
message:
STOP: 0x00000050 (0x8872A990, 0x00000001, 0x804F35D7, 0x00000000)
PAGE_FAULT_IN_NON-PAGED_AREA
----------------------------------------CAUSE:-----------------------------------------
loadTOCNode(1, 'cause');
This problem may occur if there is a conflict between Windows XP SP1
and the display adapter drivers that are currently installed.
------------------------------------SOLUTION :---------------------------------------
loadTOCNode(1, 'resolution');
To resolve this problem, start your computer in Safe mode, remove the
display adapter, rename the .inf files that are associated with the
display adapter drivers, restart your computer in Normal mode, and then
update your display adapter drivers. The following steps describe this
procedure in more detail:
1.
Start Windows in Safe mode. To do so:
a.
Restart the computer, and then press F8 while the computer starts.
b.
On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
c.
Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
2.
In the message that states that Windows is running in Safe mode, click Yes.
3.
Click Start, click Run, type msinfo32 in the Open box, and then click OK.
4.
Under System Summary, expand Components, and then click Display.
5.
In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
6.
Quit the System Information utility.
7.
Click Start, right-click My Computer, and then click Properties.
8.
Click the Hardware tab, and then click Device Manager.
9.
Expand Display adapters, right-click the display adapter, and then click Uninstall.
10.
Click OK.
11.
Click Start, click Run, type cmd, and then click OK.
12.
In the Command Prompt window, type the following commands, and then press ENTER after each line:
ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
13.
Close all open windows, and then restart the computer in the typical manner.
14.
Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
15.
When the Found New Hardware Wizard starts, click Cancel.
If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
If
you receive a "System Has Recovered from a Serious Error" message when
Windows starts, restart the computer again. This error message does not
recur.16.Obtain and install the
latest drivers for your display adapter.For information about how to
contact computer hardware manufacturers, click the appropriate article
number in the following list to view the article in the Microsoft
Knowledge Base:
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi - (Technical Associate)
