I have an unexpected problem. Yesterday I installed MX Revolution Mouse. Eveything was fine until I attempted to replace blank entries in MS Access Database fields. The progam keeps informing me that the null entries could not be found. I have been regularly using the replace option and until now have had no problems. The problem has only occured since I installed MX Revolution software. The problem I have must be connected to the installation of the mouse software. I would welcome your advice
  • LyndonB May 08, 2008
    The problem must be within the Logitech mouse software.
    I un-installed the Logitech software & reconnected my original mouse.
    Using the old mouse I had no problem replacing Null entries in my Access database.
    I the re-installed Revolution mouse software and the original problem re-occured.
    I would welome your further comments
    Incidently, in my original mail, I did not mention that once I haf installed the Logitech software I am unable to replace Null entries using my old mouse. This problem still exists after re-installing Logitech.
    Problem Solver:
  • 17 Answers
LIFO - Last In, First Out
First uninstall the software and reboot. Does it work now? If it does, it is definitely the software. If it still doesn't work, then it's not the software. Then post your findings and we'll go from there.
Please remember to rate this soltuion!
Posted on May 07, 2008
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
MY LOGITECH MX REVOLUTION MOUSE NOT RESPOND
There are a number of reasons why your mouse isn't reponding:
  1. Check that the batteries are full
  2. Check that the mouse is synchronised with the adapter
  3. Check you have the correct drivers installed.
If none of these things help you, then if your mouse is still under warranty, I'd ask for another one.
Good luck! John
Mar 13, 2011 | Logitech VX Revolution 931690-0403 Mouse
Mouse will not charge when put in the base
I have a very bad solution about this, but it works on my mouse that also doesn't work. Try to put a tiny bit of water ( or spit Oo ) on the little, usually copper, receivers on the mouse. That makes for a better contact. Just get your finger wet and touch those receivers.
May 15, 2010 | Computers & Internet
Drivers
Because you don't list what model Logitech cordless mouse you have, look in this list to see if yours is on it. If it is, click on the link and download and install the driver. This download has the latest drivers and SetPoint software for Logitech cordless, wireless and Bluetooth pointing devices (mouse).
http://www.softwarepatch.com/utilities/logisetpoint-dl.html
Specifically the mouse driver is for the following models:
  • Anywhere Mouse MX
  • Cordless Mini Optical Mouse
  • Cordless Optical Mouse
  • Cordless Optical TrackMan
  • Cordless TrackMan Optical
  • Cordless TrackMan Wheel
  • G1 Optical Mouse
  • G3 Laser Mouse
  • G5 Laser Mouse
  • G500 Gaming Mouse
  • G7 Laser Cordless Mouse
  • G9 Laser Mouse
  • G9x Laser Mouse
  • LS1
  • LX3
  • LX3 Plus Laser
  • LX5
  • LX6
  • LX7
  • LX8
  • M110
  • M205
  • M305
  • M500
  • M505
  • M555b
  • M705
  • MX 610
  • MX 610 Left-Hand
  • MX 620
  • MX Revolution
  • MX1100
  • Optical Mouse
  • Performance Mouse MX
  • Racer Mouse
  • Spot Mouse
  • Tiger Mouse
  • Trackman Marble
  • TrackMan Wheel
  • Trackman Wheel
  • V100
  • V150
  • V200
  • V220
  • V320
  • V400
  • V450
  • V470
  • V500
  • V550
  • VX Nano
  • VX Revolution
  • Zebra Mouse
I hope this helps and good luck!
Please remember to vote 073d6e6.jpg and leave a testimonial.
Nov 03, 2009 | Logitech Cordless Mouse
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
New mouse wont connect....
This is a common problem, go to the Logitech website (www.logitech.com) and download the Reconnect utility. Follow the steps given to you in the software and it should work fine! If not, is the mouse fully charged?
Nov 10, 2008 | Logitech MX Revolution 931689 Mouse
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
