Question about Frigidaire FRT21H8 Top Freezer Refrigerator
I have a 4 yr old frigidaire top mount refrigerator. The freeze keeps things frozen although it doesn't seem to run often causing condensation to drip from the top of the freezer. Ice gets frozen and everything stays frozen from what I can tell - but there is always many beads of water dripping from the top of the freezer (NOT the refrigerator). I turned the temp of the freezer down and I didn't hear it click on. It seems at times those water beads are frozen and then they defrost hours later. Thoughts?
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
My refrigerator is not cooling properly. How can I find the source of this problem?
The controls on a unit like that cannot be set to extremes on one side. If you set the freezer to the wrong setting or the refrigerator to high then the balance is bad. The other thing is that the coils inside the unit might have ice on them and the ice is not defrosting. That means that no air is flowing through them.
Oct 15, 2014 | Refrigerators
2 yr old FRIGIDAIRE WON'T COOL
check the compressor area and make sure its clean and see if the fan and compressor runs the thermister register temperature but not if not running also check the electronic board if you have the manual it will tell you the codes and how to clear them. check to see if you have warranty.
Dec 11, 2013 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Food defrosted pulled away from wall improved then defrosted again. Un plugged for day in case frozen somewhere, plugged back in and worked for a day. Now defrosted again. At times fridge has frozen food...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 23, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
Top Mount ReRefrigerator stops coolinng. The frozen items in the top freezer are softening. The bottom part of the refrigerator, though the dial is on high cool, it is not cooling--it is a bit warm. The...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 08, 2010 | Frigidaire FRT21P5A Top Freezer...
FREEZER IS NOT FREEZING FOOD OR ICE IT IS RUNNING BUT THE ICE WILL MELT IN THE ICE BOX AND WATER WILL RUN DOWN THE FREEZER DOOR, NOTHING IS FREEZING. FRIDGE PART SEEMS TO BE WORKING OR KEEPING FOOD COLD....
heatman101
Sep 08, 2010 | Frigidaire GLRS267ZA Side by Side...
4 yr old Top Mount Frigidaire freezer is not freezing
Even after you had unplugged and started if the fridge is not cooling well then the compressor is not having the right pressure for the heat exchange. The possible problem can be fault in the compressor or lack of gas in the system. check if the compressor motor speed is fine and pumping well, need to use a current test witth a clamp tester. If not check on the contacter relay, the capapcitor. If ok the gas pressure must be checked or refilled. I hope you can follow this out and try. Good day,
Jul 27, 2010 | Frigidaire FRT21H8 Top Freezer...
My fridge side out the blue is freezing. All
I had the same problem with mine a few years ago. After two thermostat replacements and still having the problem, the third technician out explained that if you blocked the vent on the inside of the refrigerator, (the shelf below meat drawer,left side) it could cause freeze up. Sure enough, haven't had a problem since.
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer freezes up and don't know if there is a reset
sounds like the condenser is bad, feel the copper coils they should be cold and the condenser should be hot/
May 20, 2009 | Frigidaire Gallery GLHT214TJ Top Freezer...
Whirlpool refrigerator Model Number ET1FTTXKQ03 Keeps freezing
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 10, 2008 | Whirlpool ET9FHTXMQ Top Freezer...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
167 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
