Question about Intel D865GBF Motherboard
VGA Dear helper can i use ram to make my on-board VGA stronger ? thanks
  • SAM_WHAN May 07, 2008
    now here s the quetion how do i do thet and how much RAM do i need for the 256 option?
    thaks but I need more info like how do i do thet and how much ram do i need and what is the max for the VGA?
    thanks
  • 27 Answers
In which way do you mean stronger? You can allocate more memory from your RAM to the on board graphics card, but this only will help to a point. You can do this from in the BIOS.
Hope that helps?
Posted on May 07, 2008
I replaced my ram and now my monitor won't work. I took out the new ram, put the old back in and still no monitor. Everything I read mentions video card...where is that?
Being eMachines it is probably on board VGA. You can check by looking to see if the VGA lead to the monitor plugs into a VGA card or the motherboard.
Unfortunately it may be caused by static discharge when the RAM was replaced if you didn't observe anti static precautions.
Hope its a VGA board fault but if you install a VGA card and turn off the on board VGA that will work.
Hope that helps.
Dec 30, 2010 | eMachines W4685 PC Desktop
I have Intel DH55TC Mother Board cannot get display when i remove ram from board board get beep & i also change ram but same problems
Always Provide Proper Details.
1. Processor
2. Motherboard
3. RAM With Company Name
4. Graphics Card Detail
After Reading Ur Comments I Want 2 Know How Many Beeps You Hear....
Beep Details.......
2 Beeps Shows Graphics Problem
Use PCI-E Graphics Card Like ATI OR NViDiA.
3 Beeps Shows RAM Problem
Use Another RAM OR Try The RAM In Another Slot OR Channel.
Hope This Helps....
Oct 11, 2010 | Intel DH55TC Motherboard
I'm installed a brand new Mother Board ASUS P5QPL-AM + E2200, and using Kingston kvr667d2n5/512. when i turn the power on, Fan, keyboard, mouse and the other are all on, except the monitor, and there a...
Yes it could be a video/motherboard problem.
1st Install a different RAM module because the RAM may be faullty and the on-board video card uses part of the RAM (shared memory).
If this works then the RAM is either faulty or incompatible.
2nd. Try installing a video card in the AGP expansion slot.
Sep 09, 2010 | ASUS P5QPL-AM - Motherboard - micro ATX -...
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
REGARDING MEMORY
Sir you have to check in bios that nay mmory shared with grapihic also disabpel sahoadow memory.
Jun 09, 2009 | ASUS P5PE-VM Motherboard
Display blanks and on board buzzer beeps
check your RAM >remove it > Cleen it > Fix it back> Try turning ur PC on again
Still no????
Check your VGA>remove>cleen>fix>switch on Pc
Still no?? use another RAM and try or a VGA....
3 beeps indicate...VGA problem
Conituous beep indicate....RAM problem
Apr 10, 2009 | Bernina Artista 180
Halo
you have on board video which in some cases uses some of your ram as video memory.
hope this helps
Jan 06, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
What is the maximum onboard VGA support from Intel D865GBF?
This board supports uses Intel Extreme Graphics 2 for its onboard video memory but even Intels site does not explain how much memory it has or if it shares RAM for video memory. Your manual can be found here
http://www.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
May 12, 2008 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
