Question about Canon imagePROGRAF iPF9000 InkJet Printer
My Canon IPF 9000 keeps tearing up the paper when loading, especially the thinner stuff, it gets caught up under the ink carriage and then bunched up and then I have to switch the whole thing off and one....it's wasting a ton of paper and time
  • Canon Master
  • 17,129 Answers
Use only the recommended printing paper in your printer or else the rollers will chew them off and cause more harm.
A thin paper can move off with the roller unlike a thicker one as the gap in the roller is set for the printing paper.
So please check this out.
Posted on Aug 28, 2010
  • artbyalice Nov 13, 2010
    Put a little bend in the edge of the paper, bending the whole edge upwards slightly before letting the printer load it, this should prevent it from getting caught up and bunched up under the printer window, which is what happens to me....this is the fix that works for me, hope it helps
How to Fix Canon MP600 Paper Jam With no paper jammed?
I can understand your frustration, but if you promise to clean up your language, I will try to help you. :-)
It is possible that your step motor guide is dirty and as a result it thinks that the carriage is not moving properly. The step motor guide is a film about 4 mm wide that is stretched along the course of the carriage. You should be able to see it by using a flashlight with the cover raised exposing the ink carriage. It will be at the back of the carriage about level with the top of the ink cartridges.
Turn off your printer. Take some Q-tips and some alcohol (isopropyl). Soak one end of the Q-tip in alcohol and then gently rub along the top of the film. Change surfaces of the Q-tip as it collects up ink and dirt. Keep doing this until the Q-tip can pass along the film and remain clean. Repeat this for the underside of the film. Once this is clean and dry, move your carriage manually to the left and clean the area where the carriage sat.
If this doesn't work, then there might be a sliver of paper caught in the microswitch where the paper exits. There is also a remote chance that the connection to the switch is defective, but I would suspect the film first. Hope this helps.
Aug 09, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Blicking light canon d480
try this
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 18, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Hello, i'd like to ask for advice. I have this one problem with canon ipf 8000, we've been using Schoeller H 64160 photopaper for poster printing with no problem. But recently we got different type of...
iI would check your paper type setting. you are working with a liquid type of ink and water will effect it. check the drying time of this ink. set your paper type to the set the type most suitable for this paper. try heavy gloss. you will find it under paper settings in the main menu. If no luck refer back to the ink and its compatibiliy with your ipf 8000. now if these are a recharged cartridges. you should change to the oem. meaning" original engineering manufacture".
Apr 09, 2017 | Canon imagePROGRAF iPF8000 Printer
Paper keeps getting jammed
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.
Nov 23, 2010 | Lexmark Office Equipment & Supplies
How to fix paper jammed error of canon mp145
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jun 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam
alternative :
Apr 07, 2009 | Canon Laserbase MF6530 All-In-One Printer
My Canon iPF 9000 continues to have Hardware Errors 03800500-2F2F
Clean the area below where the carriage rests, where it dumps ink into the maintenance cartridge. Apparently the sensor is not detecting how much in is being dumped or not even detecting ink at all.
Hope this helps
Mar 26, 2009 | Canon Office Equipment & Supplies
Reset Ink Tank for Canon IPF 610
How do you reset the waste ink tank on the IPF700? Would appreciate it if someone could help me.
Thanks
Nov 10, 2008 | Canon imagePROGRAF iPF8000 Printer
Paper jam
try this
alternative :
May 04, 2008 | HP 610 Color Copier
Canon imagePROGRAF  iPF9000 InkJet Printer Logo
145 people viewed this question
old marine
old marine
