Question about Kitchen Ranges
I have just purchased a westinghouse gas wall oven with separate electric grill, model GXN650SNG. After using it for about 1 week it has started switching itself off during operation. This is usually around 10mins but is now occurring more often. I can not get the end time to stay on zero, it keeps reading the same as the clock time, does this have anything to do with the oven not working. I have turned the power off and back on after 30mins to erase any error in the cook time/end time/timer/clock memory but this has not made any difference. I have contacted the service centre but have been informed there is a 3 week wait for service. As I do not wish to void my warranty I can not request service from elsewhere, however I need to use the oven each day. I would appreciate your help in solving this problem or at least receive some advice as to where I can go to for more efficient service. Kind Regards, Cindy Williams
  • malcolm_wlls Aug 31, 2008
    we have had our stoves 1200 DFS for 6 years now. We have had the same problem throughout its life. We had the thermostats changed on both ovens 3 years ago and although improved a little, still wasnt reliable. It is now worse than ever, we cant rely on either oven to remain on. We are calling the service guy again, seems a shame to buy a new oven as otherwise its still like new??
    Genius:
  • 1,073 Answers
Need to wait for factory service they are right about outside help. or call the dealer that you purchased it from for some help
Posted on May 08, 2008
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Need Westinghouse gas wall oven AWGB700FP manual
Request the manual directly from Westinghouse.
Jul 20, 2014 | Ovens
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
I am purchasing a home with a kenmore elite gas range model # 790.3670--the seller doesn't seem to know if the oven is electric or gas. What is standard?
Electric or gas would be standard. If this is a stove like in the picture you provided, and is gas on top ... it is probably gas inside. You could always look to see if it has a burner or a calrod. See if there is a setting for Pilot or Igniter. Electric ovens don't need a pilot nor an igiter.
Of course, you could turn it on ... or pull it away from the wall to see what the connection is ... gas pipe or, if electric is involved, a very heavy electric cord - probably 50 amp 220 volts. If it has a small cord plugged into a standard wall outlet ... definitely gas fired. You say the top is gas so there will be a flex pipe for the gas ...
I searched Sears - they claim there is no such model.
Your agent should be able to tell by looking.
Mar 24, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
