Question about LG LSC26905TT Side by Side Refrigerator
Our refrigerator stopped abruptly with no warning or noise. If it is the 20 amp fuse where do I look since the refrigerator has a panel on the top along with the panel in the rear. Which one do I take off to find this fuse. Thank you.
    President:
  • 1,796 Answers
The fuse should be on the rear panel.
Posted on Aug 28, 2010
What caused it to stop working?
An internal fuse may have opened or the power supply could have failed abruptly.
Nov 25, 2015 | Televison & Video
Put something to heatup after pushing start made standard startup noise then abruptly stopped working even electronics....breaker fine and receptacle working....does this unit have a fuse??
Almost all microwaves have internal fuses. Counter top micros need to remove outer case and fuse should be near where power cord enters the microwave, Fuse looks like old style glass car fuses but is white or gray ceramic. Can't look at it to tell if its bad. Need tester. Over the range (wall Micros) usually have the fuse directly behind the control panel which you will need to drop down away from the body. Same type fuse as stated before. 15 or 20 amp should be stamped on metal edge. Purchase at Radio Shack or a parts store---or some Hardware stores.
Mar 31, 2015 | Microwave Ovens
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
How do I find the fuse panel on LG model LSC269055b refrigerator
I think your model number is actually LSC26905SB
There isn't a fuse panel, per se. If I remember your model correctly, the main board is on the back, so pull your refrigerator out, unplug it, and take off the access cover located about halfway up your refrigerator's back. Look at the fuses on the main board. There is a 20 amp fuse that blows easily (the newer boards have a slower blowing fuse in them, now). Temporarily jumper the 20 amp fuse and then plug your refrigerator back in. If you hear relays clicking and such, that's good. The compressor should start up shortly afterwards and all the lights should be on in your refrigerator.
After you have verified operation, go to Radio Shack, or somewhere similar and get yourself a 20 amp slo-blo (slow blowing) fuse and solder it on top of the old fuse on your main board.
Remember to always unplug your refrigerator when dealing with the main board and power circuits.
Good luck and let me know if you need any more help.
Nov 17, 2014 | LG Refrigerators
My 1983 Monte Carlos fuse box labels are worn off. I need to know if I got all the fuses I need or if am missing fuses
1. 5 Amp (Tan) - Instrument panel lights and lights-on reminder
2. 20 Amp (Yellow) - Choke heater
3. 30 Amp - Circuit Breaker. Power windows and sunroof
4. 10 Amp (Red) - Electronic control module
5. 25 Amp (White) - Heater and air conditioning
6. 20 Amp (Yellow - Stop and hazard lights
7. 25 Amp (white) - Windshield wipers
8. 10 Amp (Red) - Radio and cruise control
9. 30 Amp - Circuit Breaker. - Power door locks, seats and rear window defogger
10. 20 Amp (Yellow) - Courtesy lights, key warning chime, power antenna, horns, cigar lighter and clock
11. 20 Amp (Yellow) - Turn signals and back-up lamps
12. 20 Amp (Yellow) - Parking, side marker, license plate and tail lamps
13. 10 Amp (Red) - Warning lamps and buzzers, trunk release, torque converter clutch and vehicleicon1.png
speed sensor
May 11, 2014 | Cars & Trucks
Passenger wheel chirp / squeak that stops when brake is applied
sounds like a brake pad warning clip is making contact with the rotor applying brakes presses pad and quiets the noise. have pad wear checked by mechanic.
May 17, 2013 | Chrysler Town and Country Cars & Trucks
Words on fuse box diagram faded. whats the appropriate fuses?
Please review this article: Where's The Fuse?
speed sensor
14. Not Used
Jun 08, 2011 | 1983 Chevrolet Monte Carlo
My fuse box cover has numbers to show what fuses go to what, I need a list of the numbers
1. 15 AMP Dome Lamps, Power mirrors (on 2 door models only), radio memory
2. 6 AMP front washer/ wiper
3. not used
4. 15 AMP stop lamps, 4 way flasher
5. 15 AMP back-up lamps, daytime running lights, rear defrost, turn lamps and turn indicator
6. 10 AMP speed control
7. 15 AMP instrument cluster warning lamps (explorer limited model #7 is 15 AMP heated outside mirrors)
8. 20 AMP horn
9. 10 AMP air conditioner switches, clutch coil
10. 15 AMP Park/ license plate lamps, trailer tow connection
11. 15 AMP radio
12. 20 AMP cigarette lighter, flash bright lights(from signal arm)
13. 10 AMP instrument panel illumination
14. 30 AMP power windows
15. 10 AMP ABS module
16. 20 AMP premium radio amplifier
17. 15 AMP rear washer/ wiper (explorer limited model #17 is 15 AMP warning gauges and lamps, 4 wheel drive)
18. 15 AMP heated exhaust gas oxygen
that's you list. hope it helps.
Aug 26, 2010 | 1992 Ford Explorer
Engine management fuse keeps blowing
My car stopped running without any warning, its a 2005 ford focus, 2.0 and the 20 amp fuse for the engine management keeps blowing, it's number 9 in the panel and I have replaced it twice, both times it blew again, any tips? Also the odometer reads ------ and that's it.
Jan 09, 2010 | 2001 Ford Focus
ERROR EE2 WARNING
one bad toner has jammed or toner drive clutch has fault. open right cover and you can see witch clutch makes noise. or toner drive moter has problem.
Sep 05, 2008 | Brother HL 2700CN Laser Printer
LG LSC26905TT Side by Side Refrigerator Logo
61 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
