Severe Problem With Dell Monitor
I have a Dell Monitor Model No.D1028LR. On turning the switch on screen flashes for less than a second and then goes off.
Can somebody give me service manual for the above model number.
  • dear_nitin May 17, 2008
    I am sorry for rating previous solution inappropriate. In fact I wanted to rate it in positive.
    Thanks for trying. But my problem still persists. Please help me.
    Can somebody give me Free service manual/Circuit Diagram for the above model number.
  • 40 Answers
Try to search on eserviceinfo.com
u must get help.
regards
mailme ur response @ vishwas_4u@rediffmail.com
Posted on May 08, 2008
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Monitor does not want to wake up. Pressing the yellow rest switch the button goes green for less that 3 seconds, then goes yellow.
try unplugging your computer and your monitor for about a minute and turn back on. Then see if it works, Good Luck ;)
Nov 12, 2009 | Dell E177FP LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Today I noticed that when turning on computer, after 1-2 mins the screen goe black and I cant see anything. I noticed in the past month that occasionaly I get lightening flashes in the background. this...
To determine if the LCD screen is faulty ot the video card, connect an external monitor to the laptop's video port. Power up the external monitor first and the boot up the laptop. The video image should automatically switch to the external monitor. If you don't get flashes on the monitor then the video card is OK and the fault lies with the LCD screen. Flashes coud be caused by a faulty inverter or a faulty CCFL lamp. A fault is usually easier to diagnose when it is not intermitten.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Apr 09, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Flat Screen Monitor
hello can someone help me?? the problem is when i turn the monitor on i just can see shine white i can do anything my monitor is del E197FPf lcd thanks a lot
Jun 25, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
611 people viewed this question
David Payne
David Payne
