Question about Garden
I have a binks 2001 spray gun that I want to use to spray Wilsonart 951 contact glue. Wilsonart suggests a 63BSS fluid nozzle with a 66SDJG. The manual for the spray gun gives several options under the heading of adhesives, including a 66SS fluid nozzle paired with a 66SD-3 air nozzle. I want to use these latter nozzles because it will save me from having to purchase the ones Wilsonart suggests. Will these work as an alternative to those suggested by Wilsonart?
  • hausmann Aug 29, 2010
    Yes, thanks!
  • 10,319 Answers
You can use the one it has already. add some mineral spirits to the adheisive so it will spray thinner. add several coats spacing the time to 3 minutes apart. it will take longer to get tacky and save some money as well
Posted on Aug 28, 2010
My binks 2001 will not pick up paint under 60 psi, and at that must be very thin!
I think I would 1st check to make sure the fluid nozzle is not leaking (sucking) any air. There may be a small piece of debris between the nozzle and body causing it not to be completely sealed.
Another place to check would be the pick up tube to the main body.
If you don't have one, here's a link to the manual for your spray gun.
http://www.binks.com/Portals/0/repository/77-2626.pdf
Hope this helps.
Jun 14, 2014 | Binks Air Tools & Compressors
What is a spray nozzle for my hot glue gun?
A spray nozzle is an optional accessory that may be a useful addition to your spray gun on some projects. Compressed air is used to force a controlled amount of glue out through a specially designed nozzle which sprays it, as opposed to globbing it out of the original nozzle. This is useful when you want to spread a thinner layer of adhesive, but due to its thinness it will dry quicker- usually within a few seconds.
Feb 26, 2013 | Crafts & Hobbies
I bought a spray gun and wanted to know the difference between the two air caps one is numbered 36SD and the other is 67PD I have a binks spray gun.
67PD PE Used for Zinc rich and other abrasive coatings, the 36sd is a general nozzle that is used for most applications, if you need assistance,, heres their number Technical Support Tel. 888-992-4657 Fax. 888-246-5732 or you can check their PDF located here . http://www.southernfluidsystems.com/BICONV.pdf
Apr 22, 2011 | Binks Model 7 Conventional Suction Feed...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
Siphon tube on cup gun blows into the cup
Other than a missing or deformed gasket ring around the nozzle assembly, there might be a gun casting leak from the air passages to the fluid passages. Hope this helps!
Apr 02, 2010 | Binks SPRAY GUNS & OUTFITS
I have binks model 21 automatic guns on my striper i installed rebuid kits when testing with water the guns drip water from liquid nozzle but not from needle it seats properly is this normal and will not...
If it is leaking fluid from the holes in the nozzle then the tip is not making good contact with the seat, the seat of the nozzle could also be dinged, or the tip / gun gasket might be bad. If the water is coming from the needle / nozzle seat, the needle or inside seating area of the nozzle could be nicked.
Nov 25, 2009 | Binks Air Tools & Compressors
Delivers the product but has a pulsating spray Binks Model 7
There is actually very little in the gun in the way of parts. The outer front nozzle unscrews, then the inner nozzle (you need a thin open-end wrench). The fluid and air controls unscrew from the back with loose springs. The fluid needle pushes out the back and the air valve unscrews from the front side of the handle (you may need to remove the trigger to get the valve out). The only critical area is outer and inner passages of the two front components. Soak the entire gun and parts in gun cleaner for an hour or two, then blow everything clean with compressed air. Lightly lube the trigger bearing, fluid needle (not the thin part), and air valve assembly. Put a little light grease on the threads of the two controls and their springs. Don't oil anything around the nozzle. Hopefully, you found a wad of paint in the gun body after soaking it. After reassembly, check the air flow first which should not pulsate. If it does, check the air line with a blow gun--does it pulsate? Check the regulator, hose, and air filter if it does. If the air delivery is good but the gun still pulsates while painting, check the paint supply system. Hope this saves the gun--I've had a Binks gun for many years and it was well used before I got it.
Oct 08, 2009 | Binks Model 7 Conventional Suction Feed...
Spares for binks 630 spray gun
You can find spares for Binks 630 here: http://sprayfinishingstore.com/products/spray_gun/classics-gun/binks-630-gravity-spray-gun/
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Sep 29, 2009 | Binks Air Tools & Compressors
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
