Question about Hitachi DZ-HS300A DVD Camcorder
My camcorder dose not turn on and is not the battery or the power cord
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
Show me how and where to hook up power cord, to charge battery for camcorder, omni2
many camcorders have a power pack that attaches to the camcorder and then the battery attaches to the power pack you can also put the plug in and run the camcorder when everything's attached
Feb 26, 2015 | Video Cameras
My camera turns on when I plug in the power cord even if the power button is set to off. It does not work with a battery, only the power cord.
Hi, That sounds normal. Most camcorders will come on when plugged in. If you think there is still a problem go to a camera repair. Good luck.
Sep 15, 2011 | JVC Everio GZ-MG77 Camcorder
The camcorder has no power and will not turn on either with the battery or power cord.
The most likely culprit is the power cord. it is probably not supplying power therefore you have a camcorder with a dead battery. A simple volmeter. will test the output of the charger (should be DC 8.4V 1.5A). If it is not putting out the correct volts Then you van get one from Amazon for like ten bucks. http://www.amazon.com/HQRP-Replacement-compatible-DCR-TRV103-DSR-PD100A/dp/tech-data/B002OVMKE2
Feb 28, 2011 | Sony Handycam DCR-TRV103 Digital Camcorder
My Flipshare video camera will not turn on. When I try to power it up on my computer or with the power cord, nothing happens. No light goes on, no nothing. Pleas help!
Hi d_cockerham,
You should try resetting your Ultra HD Flip Camcorder. Unfortunaately the support knowledgebase does not list the proceedure but I managed to get an email from them on how to proceed.
The steps to reset/resolve an issue where your UltraHD will NOT turn "On" is as follows:
  1. Remove the battery pack from the camcorder.
  2. Connect the camcorder to a powered USB port on your computer.
  3. When the "Connected" indicator comes on, insert the battery pack into the camcorder.
  4. Safe eject your camcorder from your computer.
  5. Reconnect your camcorder to your computer.
  6. The battery pack should now begin to charge within the camcorder
Hope this helps anyone else who encountered similar problems.
Jan 08, 2011 | Pure Digital Flip Video Ultra Camcorder
Cannot get my camcorder to turn on. I've tried two different power cords and two different batteries, still not luck
Possibly the power management unit needs to be reset - try this: disconnect all power and all batteries from the camcorder, then press AND HOLD the power button down for 30 seconds. Release the power button, then reconnect the camera directly to an AC adapter and see if it turns on.
Oct 20, 2009 | Canon ZR600 Mini DV Digital Camcorder
Intermittent power?
when u attach the battery ..
if same problem is there ..then u need to take it to the professional person as the DD board in camcorder is having problem .. the circuit protector(fuse) may have failed in it
Jun 09, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
One of the 2 battery does not work on camcorder.
some of those batteries come with a lid on the face side of the battery where u insert a power cord in order for the camcorder to get power from the battery. (strange........ I know). the battery mounts on the camcorder but acts as as an external source of power. a cord needs to be plugged into the battery and then int the ac adapter jack in order to send power.... that is if it is anything like my camcorder.
May 30, 2009 | JVC Everio GZ-MG130 Camcorder
Computer won't turn on though plugged into wall
Make sure you have power at the outlet. Take power cord off and remove battery. Hold power button down for 10 seconds, plug just power cord. Try to turn on. If dose not work , you have a hardware issue.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
No power after charging a new battery
Bummer, especially after getting a new battery. Based on what you have described, it appears that there is something definitely fubar with the camcorder. Only thing is that you have to decide if a repair on the unit is cost effective. Given the high price of proprietary parts and labor it might be better for you to just go shopping and walk away from this unit.
Apr 08, 2017 | Canon Optura MVX3i Mini DV Digital...
Hitachi DZ-HS300A DVD Camcorder Logo
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
