Question about Dell OptiPlex GX620 PC Desktop
Dell optiplex g620
I recantly got a g620 and I had to reinstall win xp pro via flash drive. well everything went well up to the reboot after reboot it has a script error and the installation recycles. now im stuck with a compu that has no op system on it is there a way to install again from a diffrent flash drive since there is no way of any dvd or floppy install unless its usb
  • zaknalfein May 08, 2008
    I tryed your solution however it has already formated the drive for the new OS so its completly blank if you can guide me through this it would be a life saver thanks
My key board is not working, it makes nois and I have to press it so hard /hold until type a caractor. I got a new keyboard still have the same problem. now iknow problem is from the computer, not keyboard. can you help please? (Dell G 620 optiplex)
Posted on Jan 09, 2010
Burn xp into a cd. or get a recovery disk..if neither does not work search the net for an partition manager. delete the partition that has the non-workin xp on it then try to re- install..
try derecks boot-n-nuke
Posted on Apr 08, 2009
    Problem Solver:
  • 17 Answers
Check your BIOS. If it rebooted chances are it might work if you change the way the BIOS sees and boots the devices. Try rebooting without the flash drive in. What happens?
Please remember to rate my solution!
Posted on May 07, 2008
  • Brad von Oven May 09, 2008
    You basically are stuck unless you load a bootable OS. My suggestion would be to say the heck with XP and load a free OS like linux, try damn small linux. It fits on most thumb drives and will be bootable (should make life easy) http://damnsmalllinux.org/
    Are you really stuck on Windows XP for some reason? If so, you are in trouble b/c the hard drive doesn't have the correct drivers it needs to recoginize the thumb drive. You will probably have to get a external CD Rom...
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
XP will not reinstall
please press f2 and go to bio and set a default bio and install windows
May 07, 2012 | Dell OptiPlex GX520 PC Desktop
I am trying to install win xp on a dell optiplex 760, but it can't seem to boot from the cd even after I set the boot options to boot from cd. It also can't read the boot files from the usb flash...
unless the usb drive is formatted correctly the computer will not see the files as a bootable directory. if the cd is not reading try usig an external drive or loading the disc into another computer and see if it works.
Mar 08, 2011 | Computers & Internet
I reinstalled win xp on my dell optiplex 210L since then everything is working great except my integrated ethernet port will not work. I have tried to install the drivers over and over. I also flashed my...
Hello
Check in the bios that your ethernet is indeed enabled.Also check system properties for any yellow question marks listed next to ethernet connections.If you have a question mark you will need to reinstall the drivers.
Feb 10, 2011 | Dell (E210882) Motherboard
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
Jul 04, 2010 | Dell OptiPlex GX280 PC Desktop
Gx270 Willnot boot in to winodws xp
sounds luike you might have had a virise and its wiped somonthing it souldint have out you can save your things in safe mode and re do the os (reinstall windows ) if you recantly conected hardware to then unistall and disonect it then retry it
Mar 13, 2010 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX110
Try opening the PC and removing the CMOS battery for 30 minutes. This should reset everything and enable you to install XP without needing a password.
Sep 06, 2009 | Dell Optiplex GX110 (2909T) Motherboard
Cannot find the usb plug in for the usb flash drive.
Just below the power button, there is a light grey panel with the Dell logo on it. Lift this open; careful, it does not open all the way.
Apr 18, 2009 | Dell OptiPlex GX260 PC Desktop
No Ethernet controller on Optiplex XP Pro SP3
Hey evolution200.
Heres the installer file for your Broadcom Ethernet Controller:
ftp://ftp.us.dell.com/network/R132254.EXE
Get back to me and let me know if that worked out for you.
Feb 03, 2009 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
1,157 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
