Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
StoreJet 2.5 Spinning properly(sounds) but not detected
Hi
My StoreJet i bought in 2005 stopped getting detected by my computer all of the sudden. I tried 3 different computers, none can detected it. I've tested the USB cable on a different device and it seems to be working. It sounds to be spinning properly and does not have clicking sound. I hope it is not broken.
I have not recently installed any new programs on my computer and I simply turned off my laptop and unplugged it as i usually do. It stopped working as I plugged it in again hours later.
I've also tried taking the hard drive out and placing it back.
I really hope it is not broken
I take good care of this product but do you think it is because of the problem of the Harddrive case? or is it the problem of the Harddrive itself.
Thanks
Steven
  • 1 more comment
  • wakahola May 07, 2008
    i think i actually bought it in 2007 not 2005
  • quirospepe Jun 18, 2008
    The EXACT same thing happened to me. I bought mine in 2007.
  • Anonymous Jul 29, 2008
    Mine is behaving the exact same way. I can hear it spinning (no clicking) and the light blinks when I first plug it in, but my computer does not recognize it.
If it came with a Y USB cable -- try connecting both "Computer" USB ends to the computer ports. It could be power issue. Worked for me.
Posted on Mar 01, 2010
  • 60 Answers
Try the drive in a new case. if that dosent work the drive is dead.
Posted on Dec 25, 2009
2005 kia optima abs& brake light ON
Try the master cylinder if that's not it try the brake booster, but first bleed all the brake lines starting with the driver rear then move forward if no pedal then proceed to master and booster
Jan 04, 2014 | 2005 Kia Optima
GT 240 not detected
It sound like you may have a dodgy motherboard, if you have tried 2 card in the pci-e slot and neither work it's quite possible, If you can try the cards in another machine to eliminate the cards as the fault. the other thing to also test is the PSU but if the system otherwise seems stable then it's not likely this is the issue.
Mar 11, 2012 | Gigabyte GeForce GT 240, (512 MB) PCI...
My transcend storejet 25m2 does not detect my xp sp 2 pc what the **** i can do
Good day..!!Try to check at the disk management,then change drive path or mount,then ist already detected in my computer..thanks
Aug 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi, It was working fine with windows xp and a dvd drive, suddenly its not getting detected in either ports, but the blue light is on this is Transcend 500GB storejet
Try to refresh the USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
Apr 12, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi, I have Transcend Storejet 250GB Hard disk. I bought it in Jan 2010, It was working fine earlier but suddenly one day it was not detecting in my laptop but its LED is glowing. Its also not showing mass...
Hi Welcome to Fixyah,
For that case you need to detouch the enclosure of that device there must be something wrong with the enclosure. No worry the disc inside of it is not affected. You need to get the support coming from your reseller because I believe it was still under warranty.
Aug 12, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Nothing happens whe hard drive is connected
It might happen sometime if you accidently plug out your HDD before stopping it. Just check whether drive is spinning or not. You can check that by placing your hand on it to check its vibrations. If it vibrating then you can use some recovery software to recover the drive e.g. PC File recovery/USB recovery or Easy recovery. After recovery you can format the disk and start using it again. If your HDD is not spinning then it is better you replace it.
Aug 24, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Please describe the specifics of your problem below. We'll add your post as a comment to claimbustr's ''LOST COMBINATION - BRINKS SAFE 5054'' problem, and notify you when a new solution is offered.
I have Simpletech Signature Mini USB 500GB drive. All of a sudden, my computer (Windows XP) stopped detecting it. It does not have any external power supply. I tried to connect it to other computers still no success. I can hear the sound of hard disc spinning and red LED light also glows still I can not detect it.blue light lits just a second .
May 20, 2009 | Computers & Internet
Windows XP driver?
i have a Transend Storejet 2.5 which goes off whn it gets detected. plz can some1 giv me a solution for this.
Jul 17, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
558 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
